David
Also look at the programming tools, we use mostly Schneider PLCs (although we do have most other flavours on site) and UnityPro to program them. The backend of UnityPro is XML driven and so you can use Unix "Make" and your favourite regular expression/string handling tools to build the whole PLC from a script. Very handy for large I/O counts where you have a lot of similar code that becomes tedious to manage in the native click and point environment.
If you mange these scripts in CVS or similar it also becomes very easy to diff the scripts to see what might have changed between versions.
regards
Bryce Karnaghan | Controls Specialist | Australian Synchrotron
p: (03) 8540 4135 | f: (03) 8540 4200 | m: 0423 844 592
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of David Dudley
Sent: Saturday, 18 July 2009 5:50 AM
To: [email protected]
Subject: Re: GE Fanuc
Yes, I'd very much like to get in contact with your local expert.
We're looking at the AB ControlLogix and CompactLogix (particularly the
Compact) as well. Also looking at the Siemens S7-300 and Yokogawa FA-M3
product lines.
They all definitely have advantages and disadvantages.
The real plus for the AB is it's support of CIP, which puts interfacing with
EPICS fairly easy.
The Siemens - well - it's Siemens - you either love them, or you don't.
Yokogawa certainly has an interesting product with the FA, for which there
is an actual EPICS IOC that directly executes on the thing (although I'm
told it's kind of expensive - I haven't seen any pricing on it).
The GE however, seems to have the kind of power and high point count
integration we're needing. None of the other PLCs have high channel count
analogs (GE has 64 channel 16 bit), or high count Digitals (GE and Yokogawa
both have 64 bit DI's and DO's).
Other problem is space. Only the GE is going to easily fit 19" rack spaces
efficiently.
Gotta expand my spreadsheet for comparison quite a bit.
David
On 7/17/09 3:22 PM, "Elliott Wolin" <[email protected]> wrote:
> Hi,
> We plan to use Allen-Bradley ControlLogix PLC's for our control system,
> but are using GE Fanuc core-duo cpu's for data acquisition. If you have
> any interest in the latter I can put you in contact with our local expert.
> Sincerely,
> Elliott
> Those raised in a morally relative or neutral environment will hold
> no truths to be self-evident.
> Elliott Wolin
> Staff Physicist, Jefferson Lab
> 12000 Jefferson Ave
> Suite 8 MS 12A1
> Newport News, VA 23606
> 757-269-7365
> David Dudley wrote:
>> I¹m over at BNL NSLS2 now, and have been given the task of providing
>> recommendations as to the types of PLCs to support.
>> I¹ve been looking at the GE PACSystems among others, and Bob has
>> suggested I should ask on the mailing list as to whether anyone has
>> experience in using the GE Fanuc family in accelerator controls.
>> David Dudley
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
- Re: GE Fanuc David Dudley
Job Posting Eric Berryman
<2009>
2025
2026
<2009>
2025
2026
