1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cainfo does display host info
To: Carl Schumann <[email protected]>
Cc: [email protected]
Date: Tue, 21 Jul 2009 16:48:40 -0400
At some point during 3.14, the name resolution was moved into a separate thread and handled asynchronously. (Before, there were situations, where a DNS malfunction or misconfiguration could hang up an otherwise perfectly working CA system.)
As a side effect, there's now a race condition when you ask for the CA properties after connecting to a channel. If name resolution finishes first, you get the name. If it's a bit too slow, you get nothing. Installing a local caching name server increases the chance for the name resolution to finish first. It is not needed for CA to work properly, just for seeing the user/host info immediately.
BTW: a caching name server is not a bad idea, in general. Usually it improves system stability in cases of DNS trouble.
Best regards,
Ralph
Dirk Zimoch wrote:
Hi Carl,
I think the problem started with 3.14.8. When you try again, you will see that sometimes the host name is there and sometimes not. I think the CA library is a bit impatient with the name server. Maybe Jeff can have a look at some timeout.
Dirk
Carl Schumann wrote:
I ran cainfo for a PV but did not get a result for host:
[schumann@smartcon1 ~]$ caget PD_MOD1:tstable
PD_MOD1:tstable                /tmp/table_data.15901.dat
[schumann@smartcon1 ~]$ cainfo PD_MOD1:tstable
PD_MOD1:tstable
    State:         connected
    Host:              Access:        read, write
    Data type:     DBR_STRING (native: DBF_STRING)
    Element count: 1
Since the caget is working there would it appears have to be a host of some sort. Is there an explanation for the blank host field? Attempts to find an explanation at the ANL web site were unsuccessful.
Carl
RE: cainfo does display host info Jeff Hill
cainfo does display host info Carl Schumann
Re: cainfo does display host info Dirk Zimoch
Prev: Re: labview w/ CA Paul Sichta
Next: Re: labview w/ CA Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cainfo does display host info Dirk Zimoch
Next: RE: cainfo does display host info Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
