I've also been using SCA with call library function nodes in our labview
CA clients for quite some time, and it has worked very well for me.
Unfortunately I haven't been able to get the version based on 3.14 to
work properly w/ my clients. I believe there is a version based on 3.14
using ActiveX controls but I have not tried using it to any significant
extent.
dale
Paul Sichta wrote:
Wesley,
I suppose you've googled and searched tech-talk.
I've been using a Simple Channel Access (SCA) package with LabVIEW
support for years. It works but it has problems when an IOC is
rebooted, so I'm all for for a better solution but it has perennially
been a low priority.
Several methods are described at GSI:
http://wiki.gsi.de/cgi-bin/view/Epics/ConnectingLabVIEWandEPICS
National Instruments offers two solutions. The first is to buy LabVIEW
and the add-on Data Supervisory & Control Package, which has EPICS CA
support built-in. The second method which I haven't tried doesn't
require the DSC and is described at
http://zone.ni.com/devzone/cda/tut/p/id/7987
-ps
On 07/20/2009 03:06 PM Wesley Moore wrote:
tech-talkers,
Yes I know this has been done, but what's the difficulty in setting
this up? What is the preferred method and has the experience been
good or bad? It seems like the decision to support this is based on
extent of it's usage.
Thanks for any comments,
Wesley
Dale L. Brewe
PNC/XOR Argonne National Laboratory
ph: 630 252 0582 fax: 630 252 0580
Mail:
Bldg 435E sector 20
9700 S. Cass Ave.
Argonne, IL 60439
- labview w/ CA Wesley Moore
- Re: labview w/ CA Paul Sichta
Re: cainfo does display host info Ralph Lange
Re: labview w/ CA Jeffrey Holt
<2009>
2025
2026
<2009>
2025
2026
