One suggestion would be to set asynTraceIOMask=2 and traceIOMask=255 for
that asynPort in your startup script. Then reboot the IOC until it
fails and see if you can what is different in the traffic.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Thursday, July 23, 2009 4:03 PM
To: [email protected]
Subject: Vxi11
I am using ICS 8065 Ethernet - GPIB gateway. The soft IOC is built with
EPICS R3.14.9, asyn version 4.11, streamdevice version 2.4. Sometime
when I restart the IOC it dies with the following error:
## EPICS R3.14.9-ilc3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Mar 2 2009
2009/07/23 13:28:10.304 L0 vxiCreateIrqChannel VXI: channel not
established (create_intr_chan)
2009/07/23 13:28:10.304 L0 Warning -- SRQ not operational.
@@@ Received a sigChild for process 29220. The process was killed by
signal 11
@@@ Current time: Thu Jul 23 13:28:10 2009
I don't understand these error messages. I need to understand in what
way the gateway is failing so that I can explain my problem more
intelligently to the tech support at ICS. So, my question is how to
interpret the messages listed above?
Are there other users of the ICS 8065 gateway? Has anyone seen this
problem? If so what is the solution?
Zen
- RE: Vxi11 Szalata, Zenon M.
- Vxi11 Szalata, Zenon M.
<2009>
2025
2026
<2009>
2025
2026
