I am using ICS 8065 Ethernet - GPIB gateway. The soft IOC is built with EPICS R3.14.9, asyn version 4.11, streamdevice version 2.4. Sometime when I restart the IOC it dies with the following error:
## EPICS R3.14.9-ilc3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Mar 2 2009
2009/07/23 13:28:10.304 L0 vxiCreateIrqChannel VXI: channel not established (create_intr_chan)
2009/07/23 13:28:10.304 L0 Warning -- SRQ not operational.
@@@ Received a sigChild for process 29220. The process was killed by signal 11
@@@ Current time: Thu Jul 23 13:28:10 2009
I don't understand these error messages. I need to understand in what way the gateway is failing so that I can explain my problem more intelligently to the tech support at ICS. So, my question is how to interpret the messages listed above?
Are there other users of the ICS 8065 gateway? Has anyone seen this problem? If so what is the solution?
Zen
- RE: Vxi11 Mark Rivers
Re: Waveform record updating problem Eric Norum
<2009>
2025
2026
Re: Waveform record updating problem Prachi Chitnis
<2009>
2025
2026
