John,
I am using the essentially the same setup as you (VS2005, Make 3.8.1, etc) and I am able to build base 3.14.10 with SHARED_LIBRARIES=NO and STATIC_BUILD=YES without that error. I would try to track that down, since building a static executable is less hassle for moving it around.
You can certainly just comment out the build of the testIPServerApp from the asyn/Makefile to get around the problem you are having building asyn. Nothing in areaDetector requires the sequencer. That should let you build dynamically, but I can't guarantee it, since I have only tested building things statically on win32-x86.
Sent: Wed 8/5/2009 3:38 PM
To: Mark Rivers
Cc: EPICS Tech-Talk
Subject: RE: Building ASYN on Windows
Mark, et al.,
I tried to build 3.14.10 base with
but get a new error (see below). I am able to build 3.14.9 with these
options and the same tools.
I am trying to eventually build areaDetetor 1-4 (requires 3.14.10) on
Windows (for use with Point Grey Research Flea2 camera). Can I do this
without the sequencer? In that case I could use the SHARED_LIBRARIES=YES
option as suggested by Richard Pastrick?
I don't have other plans to use the sequencer.
John
link -nologo /LTCG /incremental:no /opt:ref /release /version:3.14
-out:genApps.exe genApps.obj gdd.obj gddTest.obj gddAppTable.obj
gddNewDel.obj gddAppDefs.obj aitTypes.obj aitConvert.obj aitHelpers.obj
gddArray.obj gddContainer.obj gddErrorCodes.obj gddUtils.obj
gddEnumStringTable.obj ../../../lib/win32-x86/Com.lib ws2_32.lib
ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Generating code
Finished generating code
"Installing created file ../../../bin/win32-x86/genApps.exe"
../../../bin/win32-x86/genApps.exe ../O.Common/gddApps.h
make[3]: *** [../O.Common/gddApps.h] Error -1073741819
make[3]: Leaving directory
`W:/winDev/epics/R3.14.10/support/base/src/gdd/O.win3
2-x86'
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory `W:/winDev/epics/R3.14.10/support/base/src/gdd'
make[1]: *** [gdd.install] Error 2
make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/base/src'
make: *** [src.install] Error 2
> John,
> That is probably a problem with the epicsShareFunc stuff. It looks like
> you are building with SHARED_LIBRARIES=YES and STATIC_BUILD=NO. I know
> that it works OK with SHARED_LIBRARIES=NO and STATIC_BUILD=YES. I like
> the latter settings, because then you can take your .exe file to any
> Windows machine without having to also copy dozens of DLLs.
> Mark
> ________________________________
> From: [email protected] on behalf of John Dobbins
> Sent: Wed 8/5/2009 1:30 PM
> To: EPICS Tech-Talk
> Subject: Building ASYN on Windows
> All,
> I am building ASYN 4-10 wth EPICS 3.14.10 on a Windows machine using
> Visual Studio 2005, Microsoft C/C++ Optimizing Compiller Version
> 14.00.50727.762 for 80X86, Perl 5.8.9, GNU Make 3.8.1
> The testIPServerApp generates the link error reported below.
> Any advice appreciated, thanks.
> John Dobbins
> Cornell University
> Lab for Elementary Particle Physics
> make[2]: Entering directory
> `W:/winDev/epics/R3.14.10/support/asyn/4-10/testIPSe
> rverApp/src/O.win32-x86'
> link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
> /release
> /implib:testIPServerSupport.lib /out:testIPServerSupport.dll
> ipEchoServer.obj ipEchoServer2.obj ipSNCServer.obj
> ../../../lib/win32-x86/asyn.lib
> W:/winDev/epics/R3.14.10/support/seq/2-0-12/lib/win32x86/seq.lib
> W:/winDev/epics/R3.14.10/support/seq/2-0-12/lib/win32-x86/pv.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/recIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/softDevIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/miscIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/rsrvIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/dbtoolsIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/asIoc.lib
> se/lib/win32-x86/dbIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/registryIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/dbStaticIoc.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/ca.lib
> W:/winDev/epics/R3.14.10/support/base/lib/win32-x86/Com.lib
> Creating library testIPServerSupport.lib and object
> testIPServerSupport.exp
> ipSNCServer.obj : error LNK2001: unresolved external symbol _pasynManager
> ipSNCServer.obj : error LNK2001: unresolved external symbol _pasynTrace
> _pasynOctetSyncIO
> testIPServerSupport.dll : fatal error LNK1120: 3 unresolved externals
> make[2]: *** [testIPServerSupport.dll] Error 1120
> `W:/winDev/epics/R3.14.10/support/asyn/4-10/testIPSer
> make[1]: *** [install.win32-x86] Error 2
> verApp/src'
- Building ASYN on Windows John Dobbins
- RE: Building ASYN on Windows Mark Rivers
- RE: Building ASYN on Windows John Dobbins
EDM and MEDM panels for ZTEC's EPICS oscilloscopes Boyd Shaw
<2009>
2025
2026
<2009>
2025
2026
