1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME SBC suggestion?
To: Dimitrios Tsifakis <[email protected]>
Cc: [email protected]
Date: Wed, 19 Aug 2009 12:42:19 +0200
Hi Dimitris,
If you want to use vxWorks (despite of the high cost and complicated licensing model) I suggest to use a recent version. Newer boards are not supported under older vxWorks versions. But also the opposite may be true: older boards may not be supported under new versions.
At the moment, I try to get the MVME4100 to work. It is much cheaper than MVME5100 or MVME6100 (which we call the VME toaster because of its high power consumption). But the MVME4100 board needs a quite recent compiler which is only available with vxWorks 6.7.
Generally, vxWorks 6 has some new features (e.g. real time processes) which are not used by EPICS. vxWorks 6 still supports running applications, e.g. EPICS, in "kernel space" (which is all you had in vxWorks 5). However, the vxWorks shell has changed a bit and not everything that worked in vxWorks 5 startup scripts might work in vxWork 6 startup scripts (I had difficulties sourcing other scripts). I think I can tell more once I have the MVME4100 running.
Dirk
Dimitrios Tsifakis wrote:
Hi Andrew,
Thank you for the comprehensive response!
Your recommendations are on par with what I was thinking and what most
other people have suggested to me in private emails. The MVME series of
VME SBCs seems the logical choice given that the community has great
experience with them and the two main candidate real time OSes work well
with it.
I mentioned Linux having RTAI Linux in mind, but I don't think there are
many users of that in the EPICS world. Given the magnitude of the task
ahead of me, I am willing to "go with the flow" and select vxWorks or
RTEMS, and leave the experimentation for the future.
I noticed that most similar facilities are using vxWorks 5.5, but I
believe there is another stream, 6.7. Is there any reason to stick to
5.5 or is it irrelevant for the typical EPICS application?
cheers
Dimitris
On Mon, 2009-08-17 at 11:38 -0500, Andrew Johnson wrote:
Hi Dimitris,
Welcome to the EPICS community!
On Sunday 16 August 2009 18:22:33 Dimitrios Tsifakis wrote:
We currently have custom made systems based on older technology that
some may regard as obsolete. After reading a lot about EPICS on the net,
I have come to the conclusion that EPICS is the most reasonable choice
for upgrading our systems. As a first approach, I would like to replace
the current VME SBCs in the computer control crates with more modern
ones that can run vxWorks, RTEMS or Linux of some sort. After doing a
quick survey of the market, I have come to the conclusion that there are
many choices that will meet all the requirements, but are there any VME
SBCs that are preferred by the community for use with EPICS?
EPICS should run on almost any VME SBC that has a BSP for the appropriate OS, but the community has experience with a limited subset of the boards available, and if you're going to need much hand-holding you might be better off limiting your choices to those about which we can answer questions.
Your first issue should be what RTOS you're going to use.
I don't recommend choosing Linux for VME SBCs because of the complications of writing kernel device drivers for Linux, especially since a standard VMEbus interface has only very recently made it into the Kernel staging area. It is possible to mmap() VME cards into user space, but interrupt response from such configurations leaves quite a lot to be desired. Of course if you have experience in this area then Linux may work out fine, but don't expect much help from us on that aspect.
That leaves a choice between vxWorks and RTEMS (unless you want to port EPICS to another RTOS). In the past most drivers were written to use the vxWorks APIs directly, but that is becoming much less common since we have an OS-independent layer in EPICS and converting vxWorks drivers to use this instead has been pretty common. As a result several recent projects have decided to use RTEMS, which avoids having to pay annual fees to Wind River.
The advantage of vxWorks is that almost every VME SBC comes with a vxWorks BSP, whereas RTEMS support is less common. The cost of paying OAR to write an RTEMS BSP for your choice of hardware is not huge though, and in your position you can probably pick boards that are already supported. VxWorks BSPs often need tweaking slightly, and having the WRS paid support won't preclude the need for developing some local vxWorks expertise so that aspect of the cost is probably about even (although longer-term RTEMS may be more flexible and work out cheaper). One advantage of picking RTEMS and a currently-supported SBC is that you can still change your mind and switch to vxWorks later on without having wasted any money paying for the OS!
If you're looking for a cheap work-horse SBC and don't need a top-performing CPU, the Emerson (formerly Motorola) MVME3100 board is well-supported under RTEMS and is used at more than one EPICS site. There are also BSPs available for the Emerson MVME5500 and MVME6100 boards if you need more CPU power. RTEMS also supports several older MVME boards such as the 167, 2700 and 2100 if you have existing hardware you'd like to re-use.
HTH,
- Andrew
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: VME SBC suggestion? Andrew Johnson
VME SBC suggestion? Dimitrios Tsifakis
Re: VME SBC suggestion? Dimitrios Tsifakis
Prev: Re: VME SBC suggestion? Andrew Johnson
Next: Re: VME SBC suggestion? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
