1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME SBC suggestion?
To: [email protected]
Cc: Dimitrios Tsifakis <[email protected]>
Date: Wed, 19 Aug 2009 09:33:46 -0500
Hi Dirk,
On Wednesday 19 August 2009 05:42:19 Dirk Zimoch wrote:
> Generally, vxWorks 6 has some new features (e.g. real time processes) which
> are not used by EPICS. vxWorks 6 still supports running applications, e.g.
> EPICS, in "kernel space" (which is all you had in vxWorks 5). However, the
> vxWorks shell has changed a bit and not everything that worked in vxWorks 5
> startup scripts might work in vxWork 6 startup scripts (I had difficulties
> sourcing other scripts). I think I can tell more once I have the MVME4100
> running.
I wonder if your sourcing scripts problem is the the same issue we found when
we upgraded to vxWorks 5.5.2 - if you use the construct
    ld < ioc.munch
in your startup script then all subsequent shell redirections to source other
scripts get ignored.  The solution is to replace the above line with this
    ld 0, 0, "ioc.munch"
which permits later shell source commands to operate normally.  I think it's
highly likely that Wind River broke both versions of the target shell at the
same time...
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: VME SBC suggestion? Thompson, David H.
Re: VME SBC suggestion? Ernest L. Williams Jr.
VME SBC suggestion? Dimitrios Tsifakis
Re: VME SBC suggestion? Dimitrios Tsifakis
Re: VME SBC suggestion? Dirk Zimoch
Prev: Re: VME SBC suggestion? Dirk Zimoch
Next: UMAC - PowerPMAC thermal issue Joe Sullivan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: VME SBC suggestion? Thompson, David H.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
