1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: UMAC - PowerPMAC thermal issue
To: Beamline Controls <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Wed, 19 Aug 2009 09:44:43 -0500
Note to DeltaTau UMAC system users (based on experience with
a cooked PowerPMAC CPU):
The passive cooling design of the DeltaTau UMAC crates seems marginal
for the requirements of the PowerPMAC CPU. For this board to
remain within nominal temps (~60C) it requires ventilated top and bottom
cover plates on the CPU slot and adjacent slot (left side).
The UMAC racks shipped with PowerPMACs are configured correctly
(see picture). http://www.aps.anl.gov/bcda/Images/ppmac_rack.jpg
The problem is when the PowerPMAC is installed in a preexisting
UMAC crate that shipped with another controller board (ie. Turbo UMAC).
These crates have solid top and bottom cover plates that need to be
replaced (or removed).
The standalone PowerPMAC board ships with one set of ventilated
cover plates for the CPU slot but not the adjacent slot. The CPU
does overheat in this configuration (> 68C).
           http://www.aps.anl.gov/bcda/Images/umac_top.jpg
The solution is to either acquire another set of ventilated cover
plates or to remove the plates altogether. This setup does run
effectively.
http://www.aps.anl.gov/bcda/Images/umac_fixed.jpg
Additional Note: Care should be taken to mount the UMAC crate
in it's natural horizontal position (front facing out) to allow
for maximum air circulation.
Joseph Sullivan
[email protected] <> 630-252-8657
Advanced Photon Source
APS Engineering Services Division
Beamline Controls & Data Acquisition Group
Prev: Re: VME SBC suggestion? Andrew Johnson
Next: RE: VME SBC suggestion? Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: VME SBC suggestion? Williams Jr., Ernest L.
Next: anyone seen this error Pierrick Hanlet
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
