1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: VME SBC suggestion?
To: Andrew Johnson <[email protected]>, [email protected]
Cc: Dimitrios Tsifakis <[email protected]>
Date: Wed, 19 Aug 2009 10:51:34 -0400
We have been running 6.2 on a 3100 for nearly 2 years and haven't had to
do this. What version is it that has the problem?
Main problem we had was hanging on to environment variables and I think
they fixed that.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Wednesday, August 19, 2009 10:34 AM
To: [email protected]
Subject: Re: VME SBC suggestion?
Hi Dirk,
On Wednesday 19 August 2009 05:42:19 Dirk Zimoch wrote:
> Generally, vxWorks 6 has some new features (e.g. real time processes)
> which are not used by EPICS. vxWorks 6 still supports running
applications, e.g.
> EPICS, in "kernel space" (which is all you had in vxWorks 5). However,
> the vxWorks shell has changed a bit and not everything that worked in
> vxWorks 5 startup scripts might work in vxWork 6 startup scripts (I
> had difficulties sourcing other scripts). I think I can tell more once
> I have the MVME4100 running.
I wonder if your sourcing scripts problem is the the same issue we found
when we upgraded to vxWorks 5.5.2 - if you use the construct
    ld < ioc.munch
in your startup script then all subsequent shell redirections to source
other scripts get ignored.  The solution is to replace the above line
with this
    ld 0, 0, "ioc.munch"
which permits later shell source commands to operate normally.  I think
it's highly likely that Wind River broke both versions of the target
shell at the same time...
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
VME SBC suggestion? Dimitrios Tsifakis
Re: VME SBC suggestion? Dimitrios Tsifakis
Re: VME SBC suggestion? Dirk Zimoch
Re: VME SBC suggestion? Andrew Johnson
Prev: UMAC - PowerPMAC thermal issue Joe Sullivan
Next: Re: VME SBC suggestion? Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME SBC suggestion? Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
