1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StripTool Y range
Date: Mon, 24 Aug 2009 14:25:08 -0400
I found the old message below in the mailing list archives; I find I am experiencing exactly the same problem, with RHEL4, StripTool 2.5.12.0, and base 3.14.10 on a 64-bit machine.
To be precise, if more than one curve is displayed, then clicking on the name of a curve to the right of the StripTool plot will cause that curve - and only that curve - to be displayed as if it was on the 0 to 100 scale.  All other curves will be displayed as if the minimum and maximum of the plot was set according to its Min-Max settings, even though the Y axis will always nonetheless read 0 to 100.  I also see the same error message that Mr. Lynch describes.
Has anyone else experienced this problem and found a way around it?
On the chance that it might be related, I also notice that toggling buttons on and off via the right-click menu tends to cause segmentation faults.  Here's a gdb backtrace:
#0  0x000000307094d031 in _XtCountVaList () from /usr/X11R6/lib64/libXt.so.6
#1  0x000000307094ca8e in XtVaGetValues () from /usr/X11R6/lib64/libXt.so.6
#2  0x000000000041da47 in callback (w=0x30709541a9, client=0x6c9250, call=Variable "call" is not available.
) at ../StripGraph.c:477
#3  0x0000003070913fa5 in XtCallCallbackList () from /usr/X11R6/lib64/libXt.so.6
#4  0x000000306bfa0184 in _XmDragUnderAnimation () from /usr/X11R6/lib64/libXm.so.3
#5  0x000000306c05abd7 in _XmIsSubclassOf () from /usr/X11R6/lib64/libXm.so.3
#6  0x0000003070925a08 in XtConfigureWidget () from /usr/X11R6/lib64/libXt.so.6
#7  0x000000306bfb400b in XmeConfigureObject () from /usr/X11R6/lib64/libXm.so.3
#8  0x000000306bfb0b04 in XmCreateFileSelectionDialog () from /usr/X11R6/lib64/libXm.so.3
#9  0x000000306bfb138f in XmCreateFileSelectionDialog () from /usr/X11R6/lib64/libXm.so.3
#10 0x000000306c05ac2b in _XmIsSubclassOf () from /usr/X11R6/lib64/libXm.so.3
#11 0x0000003070925a08 in XtConfigureWidget () from /usr/X11R6/lib64/libXt.so.6
#12 0x000000306bfb400b in XmeConfigureObject () from /usr/X11R6/lib64/libXm.so.3
#13 0x000000306bfb0b04 in XmCreateFileSelectionDialog () from /usr/X11R6/lib64/libXm.so.3
#14 0x000000306bfb108a in XmCreateFileSelectionDialog () from /usr/X11R6/lib64/libXm.so.3
#15 0x000000306c05ae97 in _XmIsSubclassOf () from /usr/X11R6/lib64/libXm.so.3
#16 0x0000003070924f5c in _XtMakeGeometryRequest () from /usr/X11R6/lib64/libXt.so.6
#17 0x0000003070939943 in XtSetValues () from /usr/X11R6/lib64/libXt.so.6
#18 0x000000307094bc07 in XtVaSetValues () from /usr/X11R6/lib64/libXt.so.6
#19 0x000000000041059d in PopupMenu_cb (w=Variable "w" is not available.
) at ../Strip.c:3494
#20 0x0000003070913fa5 in XtCallCallbackList () from /usr/X11R6/lib64/libXt.so.6
#21 0x000000306bfdc0c9 in XmCreatePushButton () from /usr/X11R6/lib64/libXm.so.3
#22 0x000000306bfdd7e8 in XmCreatePushButton () from /usr/X11R6/lib64/libXm.so.3
#23 0x000000306bfb42ac in _XmDispatchGadgetInput () from /usr/X11R6/lib64/libXm.so.3
#24 0x000000306c070c90 in _XmMenuBtnUp () from /usr/X11R6/lib64/libXm.so.3
#25 0x0000003070948591 in _XtMatchAtom () from /usr/X11R6/lib64/libXt.so.6
#26 0x0000003070948b9e in _XtMatchAtom () from /usr/X11R6/lib64/libXt.so.6
#27 0x00000030709492d9 in _XtTranslateEvent () from /usr/X11R6/lib64/libXt.so.6
#28 0x0000003070922058 in XtDispatchEventToWidget () from /usr/X11R6/lib64/libXt.so.6
#29 0x000000307092277a in _XtOnGrabList () from /usr/X11R6/lib64/libXt.so.6
#30 0x0000003070922998 in XtDispatchEvent () from /usr/X11R6/lib64/libXt.so.6
#31 0x000000000040cef3 in Strip_go (the_strip=Variable "the_strip" is not available.
) at ../Strip.c:1431
#32 0x0000000000423508 in StripTool_main (argc=2, argv=0x7fbffff0f8) at ../StripTool.c:152
#33 0x000000306aa1c3fb in __libc_start_main () from /lib64/tls/libc.so.6
#34 0x00000000004073ea in _start ()
#35 0x0000007fbffff0e8 in ?? ()
#36 0x000000000000001c in ?? ()
#37 0x0000000000000002 in ?? ()
#38 0x0000007fbffff405 in ?? ()
#39 0x0000007fbffff446 in ?? ()
#40 0x0000000000000000 in ?? ()
-Kevin Anderson
> Subject: 	StripTool Y range
> From: 	"LYNCH, Damien" <[email protected]>
> Date: 	Thu, 9 Aug 2007 16:05:28 +1000
> Hi,
> Has anyone run across a problem with StripTool 2.5.12.0 having trouble
> getting the Y range correct on the graph?
> When I specify a PV in the controls dialog the Min and Max values displayed
> there do not match the Y-min and Y-max values on the graph. The Y axis on
> the graph is always 0 to 100. Even if I modify Min and Max in the Curves tab
> of the controls dialog the graph will not change the Y axis range from 0 to
> 100.
> The following error is written to the console with the same period as the
> graph redraw interval:
> ==== StripTool Xt Warning Handler ====
> Warning:           Axis: minVal is greater than or equal to maxVal
> I see this problem when I compile it under OpenSuse 10.1, Linux 2.6, Base
> 3.14.9 on a 64-bit machine. I've compiled the same version of  StripTool on
> another machine (RedHat 9, Linux 2.4, Base 3.14.8.2 on a 32-bit machine) and
> the graphs are drawn fine.
> Thanks,
> Damien Lynch
> Accelerator IT Systems Engineer
> Australian Nuclear Science and Technology Organisation
> PMB 1, Menai NSW 2234
> T 02 9717 3662
> F +61 2 9717 3257
> www.ansto.gov.au
Prev: areaDetector R1-5 released Mark Rivers
Next: RE: StripTool Y range Kevin Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Intelligent Picomotor Control Modules from New Focus David Kline
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
