1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StripTool Y range
To: "Steven M. Hartman" <[email protected]>
Date: Mon, 24 Aug 2009 15:54:12 -0400
Thanks for replying.  You seem to be right about the pointer-size assumption problem; I was just reading some more about it at http://fixunix.com/motif/94201-xtvacreatemanagedwidget-crash.html .
I guess it's not going to be a one-line fix, then?  Line 1073 of jlLegend.c looks suspicious.
-Kevin Anderson
Sent: Monday, August 24, 2009 1:33 PM
To: Kevin Anderson
Subject: Re: StripTool Y range
Kevin Anderson wrote:
> Has anyone else experienced this problem and found a way around it?
Last I tried (~2 years ago?), StripTool was not 64-bit compatible
(lots of assumptions about pointer sizes, etc in the code). This
sounds like one of the symptoms of that. I decided to stick with
32-bit (had problems with other things at 64-bit, too). I don't
know if the StripTool maintainer is working on fixing the code.
Steven Hartman
[email protected] || 865-466-6473
RE: StripTool Y range Kevin Anderson
Prev: RE: StripTool Y range Kevin Anderson
Next: How to let Hytec8401ADC works on interrupt way ? liuping
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
