First of all thank for your info, i read something about the "SynApps"
package and it is very interesting.
I have a question: if i want use only the epid record with your
package, how do i have to set the makefile?
thank a lot!
Maurizio M.
2009/8/26, Pal Trivan <[email protected]>:
> Hi,
> I'm also a user of the epid record (which by the way is *great*). However, I
> use it here at PSI within our 'custom' environment.
> In the Epics release R3.14.8.2 it is located in the 'SynApps' package, which
> you should include.
> I would be happy to share any other information on the usage (from my
> experience), if you would like.
> Regards,
> Trivan
> Dr. Trivan Pal
> [email protected]
> +41 56 310 4558
> PSI
> Switzerland
> ________________________________
> From: [email protected] on behalf of Maurizio Montis
> Sent: Wed 8/26/2009 11:22 AM
> To: [email protected]
> Subject: problem using epid record
> Hi,
> i'm looking for to use the epid record to control an High Voltage
> Power Supply but i'm in trouble: i'm trying to compile my ioc but i
> have this kind of error:
> make[3]: *** No rule to make target
> `../../../lib/linux-x86//libepidRecord.a', needed by `testPID'. Stop.
> I've setted the Makefile in src directory specifing:
> 1) testPID_DBD += epidRecord.dbd
> 2) testPID_LIBS += epidRecord
> 3) testPID_LIBS += devEpidSoft
> where is my mastake? thanks a lot for any suggestions.
> Maurizio M.
- RE: problem using epid record Mark Rivers
- problem using epid record Maurizio Montis
- RE: problem using epid record Pal Trivan
Re: problem using epid record Ralph Lange
<2009>
2025
2026
<2009>
2025
2026
