Ciao Maurizio,
you are probably missing the appropriate configuration in the
.../configure/RELEASE file of your working tree, which has the
information about all external modules needed. In that file, you should
have an entry like
EPID=<location of the epid package>
To make things work, you will have to run make in the top level
directory of your working tree (or in .../configure directory itself)
before trying to recompile your IOC library.
Hope this helps,
Ralph
On 26.08.2009 05:22 Maurizio Montis wrote:
i'm looking for to use the epid record to control an High Voltage
Power Supply but i'm in trouble: i'm trying to compile my ioc but i
have this kind of error:
make[3]: *** No rule to make target
`../../../lib/linux-x86//libepidRecord.a', needed by `testPID'. Stop.
I've setted the Makefile in src directory specifing:
1) testPID_DBD += epidRecord.dbd
2) testPID_LIBS += epidRecord
3) testPID_LIBS += devEpidSoft
where is my mastake? thanks a lot for any suggestions.
Maurizio M.
- problem using epid record Maurizio Montis
Re: problem using epid record Maurizio Montis
RE: problem using epid record Mark Rivers
<2009>
2025
2026
Re: problem using epid record Ralph Lange
<2009>
2025
2026
