Hi Mr. Small IOC,
What is the stack size of your small IOC? Is allocating 200 bytes on the stack
OK? Apart from that, I cannot find any impact on the rest of the sequencer code.
There are other occurrences of MAX_STRING_SIZE but they are probably OK:
seq/seq_main.c line 98:
#define SCRATCH_SIZE (MAX_MACROS*(MAX_STRING_SIZE+1)*12)
But SCRATCH_SIZE is never used. It should be deleted.
seq/seq_main.c line 563:
} typeMap[] = {
"string", pvTypeSTRING, pvTypeTIME_STRING,
MAX_STRING_SIZE, OFFSET(pvTimeString, value[0])
snc/phase2.c line 153:
printf("#define MAX_STRING_SIZE 40\n");
snc/phase2.c line 400:
printf("[MAX_STRING_SIZE]");
These occurrences are related to string variables and seem to be OK for the moment.
I also looked for other hard coded limits and found:
seq/seq_mac.c line 47:
char name[50], *pValue, *pTmp;
This limits the length of a macro name (not its value) to 49 chars. Probably not
a serious problem but still quite unnecessary. A dynamic solution would be to
temporarily allocate memory of the size of the substitution sting.
The number of macros is limited to 50 by
seq/seqPvt.h line 226:
#define MAX_MACROS 50
This can be made dynamic by replacing the table with a linked list of macros.
In principle, it is not necessary to use a macro table. Whenever a macro is
referenced, it can be looked up in the substitution string. The performance loss
should be negligible. Macros are only looked up during initialization.
Dirk
Eric Norum wrote:
MACRO_STR_LEN is used only in that one function -- here's my suggestion
* Evaluate channel names by macro substitution.
#define MACRO_STR_LEN 200
LOCAL void seqChanNameEval(pSP)
SPROG *pSP;
CHAN *pDB;
int i;
pDB = pSP->pChan;
for (i = 0; i < pSP->numChans; i++, pDB++)
char cbuf[MACRO_STR_LEN+1];
seqMacEval(pDB->dbAsName, cbuf, MACRO_STR_LEN, pSP->pMacros);
pDB->dbName = epicsStrDup(cbuf);
#ifdef DEBUG
printf("seqChanNameEval: \"%s\" evaluated to \"%s\"\n",
pDB->dbAsName, pDB->dbName);
#endif /*DEBUG*/
On Sep 9, 2009, at 12:54 PM, Chestnut, Ronald P. wrote:
Mr. Expedient here.
With any luck, all the code in the sequencer uses MACRO_STR_LEN, and a
change to something larger but static (perhaps 61 or 100?) might just
work after a recompile. Doing something dynamic requires actual
thinking and more extensive testing. How about an initial static bump
with a subsequent dynamic solution?
Ron Chestnut
-----Original Message-----
[mailto:[email protected]] On Behalf Of Eric Norum
Sent: Wednesday, September 09, 2009 6:15 AM
To: [email protected] Techtalk
Subject: Re: sequencer feature request
Mr. Small IOC here.
Rather than allocating the maximum-sized space for every single name,
why not expand the name into a 'big-enough' buffer and then allocate
only the required size and copy the result?
On Sep 9, 2009, at 5:13 AM, Dirk Zimoch wrote:
I found several places in the code where the sequencer uses
MAX_STRING_SIZE+1 for string lengths of PV names and macros. In
EPICS base MAX_STRING_SIZE is defined as 40. For example in
seq_main.c:
#define MACRO_STR_LEN (MAX_STRING_SIZE+1)
SPROG *pSP;
CHAN *pDB;
int i;
pDB = pSP->pChan;
pDB->dbName = calloc(1, MACRO_STR_LEN);
seqMacEval(pDB->dbAsName, pDB->dbName, MACRO_STR_LEN,
pSP->pMacros);
#ifdef DEBUG
#endif /*DEBUG*/
It might help to replace those uses of MAX_STRING_SIZE+1 with
PVNAME_STRINGSZ.
Dirk
Dirk Zimoch wrote:
I tested the sequencer with a long name and it seems that it
truncates the PV name to 41 chars.
A seqChanShow shows the difference between the name used in assign
and the actual name used in CA:
Channel name: "DZ:45678901234567890123456789012345678901"
Unexpanded (assigned) name: "DZ:
456789012345678901234567890123456789012345678901234567890"
Dirk
Mark Rivers wrote:
EPICS base defines the maximum length of the PV name to be
PVNAME_STRINGSZ, which is currently 61 including the nil terminator.
What length limitation does the sequencer impose? Is it more
restrictive than this?
From: [email protected] on behalf of Patrick Thomas
Sent: Thu 9/3/2009 6:29 PM
Subject: sequencer feature request
I was wondering if I could ask for a feature request for the next
version of the sequencer? Is there any chance that it would be
possible
to use unlimited length record names in assign to statements?
Thank you,
Patrick
--Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
--Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
(630) 252-4793
Dr. Dirk Zimoch
- Re: sequencer feature request Eric Norum
- sequencer feature request Patrick Thomas
- RE: sequencer feature request Mark Rivers
- Re: sequencer feature request Dirk Zimoch
- RE: sequencer feature request Chestnut, Ronald P.
RE: Killing a soft IOC which doesn't have an interactive shell Rees, Nick (DLSLtd,RAL,DIA)
<2009>
2025
2026
RE: Recommendation for digitizer? Szalata, Zenon M.
<2009>
2025
2026
