1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: list all process variables
To: Noboru Yamamoto <[email protected]>
Cc: epics Techtalk <[email protected]>
Date: Sun, 13 Sep 2009 08:48:35 -0500
Hi Noboru,
The beauty of storing information about EPICS PVs (along with IOC architecture, installed controls hardware, etc.) in a relational database is that it allows one to easily track the history of an IOC's configuration such as when new PVs were added to an IOC and when PVs were deleted from an IOC.
EPICS-IRMIS workshops held over the past few years have drawn much interest, support and collaboration from several accelerator facilities (CLS, SLAC, BNL, MSU-NSCL and more). An IRMIS workshop was held this past spring at Brookhaven National Laboratory and was led by Gabriel Carcassi. Gabriel and I will both be attending the ICALEPCS 2009 conference, perhaps Gabriele and I can arrange a side-session meeting or an evening meeting to discuss future enhancements for IRMIS and recent updates to IRMIS version 3 sometime during the week of the ICALEPCS conference.
Debby Quock
Controls Group
Advanced Photon Source
Argonne National Laboratory
Noboru Yamamoto wrote:
Patrick Thomas wrote:
> Hi,
> I was wondering if there was anyway to get a list of all the process
> variables currently loaded in all the IOCs. I read that when a request
> for a particular process variable is made, each IOC gets the request and > has to look in its databases to see if it contains it. Is it possible to
> instead have it return all the process variables it does have?
> I was also wondering if anyone has had trouble getting the sound to work
> when compiling the alarm handler on Linux?
> Thank you,
> Patrick
A thread in TechTalk titled "Listing channels” by David Dudley dated May 06, 2008 and responces may also help you.
In these responces, I reporeted my device support for waveform record:
devWfDbRecfection
1. A device support for waveform record. It get a list of record types/fields of specified record/name of reocrds from EPICS DB using dbStaticLib. 2.Now Supports CHAR and UCHAR as FTVL. It returns comma separated list of informaiont as char array.(2009.3.20)
and tar.gz file is available at:
  http://www-acc.kek.jp/EPICS_Gr/products/Records/DbReflectionApp.tgz
To achieve your goal, you need to install records using this device support in ALL IOCs you have.
Alternatively,
You can use dbDumpRecord and dbDumpRecorType commands,or just "dbl", in iocsh to dump those information to a file. Again you need to add these command(s) in every st.cmds in your system.
If you can safely assume you know the location of all start-up command files of running IOC, a PV Crawler can find all records in your system.
In this case, we also assume that database files used in the start up
commands have not changed since last reboot of IOCSH.
Anyway, It is interesting that this kind of question raised several times in TechTalk, and several different solutions were shown. Doesn't it means we need to do something in the Collaboration, "provide FAQ on this subject" or "Define new protocol
to retrieve these information" for examples?
Noboru Yamamoto
J-PARC control group/J-PARC center(KEK & JAEA)
EPICS group/KEK
JAPAN
RE: list all process variables Chestnut, Ronald P.
list all process variables, linux alarm handler Patrick Thomas
Re: list all process variables Noboru Yamamoto
Prev: Re: list all process variables Noboru Yamamoto
Next: Patch for alarm.h in 3-14-11 David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: list all process variables Chestnut, Ronald P.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
