1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: list all process variables, linux alarm handler
Cc: [email protected]
Date: Mon, 14 Sep 2009 21:09:39 -0400
Hi all,
I'm having a terminology issue someone might help with, because the comments posted on this thread appear to mix 'record' and 'PV' terminology interchangeably. Most of the time it's clear, and although there is a reasonable '1 to n' relation between the two, I can think of example that relation can break. To give an example, say:
   ioc1 uses old xxx record type, that does not have .YYY field
   ioc2 uses new xxx record type, that has a new .YYY field
xxx 'record' (dbl/dbgrep etc) report the same thing.
but ioc2 use a newer version that might add/remove some fields (that I think is what we really call PV = I think of it as the entity you get over channel access)
So what does pvCrawl really look at: PVs or records? does it figure in my example field .YYY exists in ioc2 but not ioc1?
Thanks
Matthieu
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
Re: list all process variables, linux alarm handler Don Dohan
list all process variables, linux alarm handler Patrick Thomas
Re: list all process variables, linux alarm handler Brian Bevins
Prev: Re: MBBO Record Initialization Maren Purves
Next: Re: list all process variables, linux alarm handler Don Dohan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: list all process variables, linux alarm handler Brian Bevins
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
