1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: db folder
To: [email protected]
Date: Wed, 23 Sep 2009 16:48:12 -0500
On Wednesday 23 September 2009 16:23:54 Patrick Thomas wrote:
> Does makeBaseApp -t ioc normally create a db folder in the top
> directory, or does that get made by the user?
Neither; directories such bin, db, dbd, doc, html, include, and lib will get
created at build time when make has something that needs to be installed in
the relevant directory.  Note that if you do a 'make distclean' at the top
level, these directories *and their contents* will be deleted, so it is a bad
idea to add files to them manually as they might not have a very long life.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: db folder Patrick Thomas
Prev: db folder Patrick Thomas
Next: Re: db folder Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
