I'm sorry, I don't quite follow, where do I put the .db files that will
be loaded by the ioc? Do I have to put something in one of the Makefiles?
Andrew Johnson wrote:
On Wednesday 23 September 2009 16:23:54 Patrick Thomas wrote:
Does makeBaseApp -t ioc normally create a db folder in the top
directory, or does that get made by the user?
Neither; directories such bin, db, dbd, doc, html, include, and lib will get
created at build time when make has something that needs to be installed in
the relevant directory. Note that if you do a 'make distclean' at the top
level, these directories *and their contents* will be deleted, so it is a bad
idea to add files to them manually as they might not have a very long life.
HTH,
- Andrew
- RE: db folder Mark Rivers
- RE: db folder [SEC=UNCLASSIFIED] LYNCH, Damien
- Re: db folder Ralph Lange
- db folder Patrick Thomas
- Re: db folder Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
