You can put entries in the xxxApp/Db/Makefile, and then make will copy the .db files to the TOP/db directory. But you don't have to do this if you don't want to, you can have the IOC directly load the .db files out of the xxxApp/Db directory. The latter is what I do, because I deploy EPICS on sites where they don't have a build system, and so can't run make. So we just use the .db files in the Db/ directory.
From: [email protected] on behalf of Patrick Thomas
Sent: Wed 9/23/2009 5:38 PM
To: Andrew Johnson
Cc: [email protected]
Subject: Re: db folder
I'm sorry, I don't quite follow, where do I put the .db files that will
be loaded by the ioc? Do I have to put something in one of the Makefiles?
Andrew Johnson wrote:
> On Wednesday 23 September 2009 16:23:54 Patrick Thomas wrote:
>> Does makeBaseApp -t ioc normally create a db folder in the top
>> directory, or does that get made by the user?
> Neither; directories such bin, db, dbd, doc, html, include, and lib will get
> created at build time when make has something that needs to be installed in
> the relevant directory. Note that if you do a 'make distclean' at the top
> level, these directories *and their contents* will be deleted, so it is a bad
> idea to add files to them manually as they might not have a very long life.
> HTH,
> - Andrew
- Re: db folder Patrick Thomas
- db folder Patrick Thomas
- Re: db folder Andrew Johnson
RE: db folder [SEC=UNCLASSIFIED] LYNCH, Damien
<2009>
2025
2026
<2009>
2025
2026
