Then maybe your /usr/lib(64) is not included in the LIB variable. It
happened to me before, when I was compiling EDM on a 64bit ubuntu
using GCC 4.3.3, it can't find libXm, blahblah. Well, since that's not
my laptop and I'm not supposed to jeopardize the system environment, I
just make some symbolic links to /base/lib so it can move on to the
next step. I'm not sure if this message could be helpful.
On Thu, Sep 24, 2009 at 10:35 AM, Patrick Thomas
<[email protected]> wrote:
> There is a copy there as well.
> Mark Rivers wrote:
>> I think that is the 32-bit version, and you need the 64-bit version, which
>> will be in usr/lib64
>> Mark
>> ________________________________
>> From: [email protected] on behalf of Patrick Thomas
>> Sent: Wed 9/23/2009 9:02 PM
>> To: Zhichu Chen
>> Cc: [email protected]
>> Subject: Re: alarm handler on base 3-14-11
>> I think it is installed, there is a libncurses.so.5 file in /usr/lib.
>> Zhichu Chen wrote:
>>> Install ncurses library by yourself.
>>> On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
>>>> Thank you, that seems to have worked. However, now it errors on 'cannot
>>>> find
>>>> -lncurses' for g++ -o alh.
>>>> Mark Rivers wrote:
>>>>> This is a common change required in 3.14.11.
>>>>> You need to "#include menuYesNo.h" and YES needs to be changed to
>>>>> menuYesNoYES.
>>>>> Mark
>>>>> Sent: Wed 9/23/2009 8:00 PM
>>>>> To: [email protected]
>>>>> Subject: alarm handler on base 3-14-11
>>>>> Hi,
>>>>> I was wondering, I get a compile error on force.c when running make on
>>>>> the alarm handler with epics-3-14-11, on 64 bit linux:
>>>>> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>>>>> -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
>>>>> -D_REENTRANT -O3 -Wall -m64 -g -I. -I../O.Common -I.
>>>>> -I../os/default -I.. -I../../../include/os/Linux -I../../../include
>>>>> -I/users/thomas/epics/base/base-3-14-11/include/os/Linux
>>>>> -I/users/thomas/epics/base/base-3-14-11/include -I../os/Linux
>>>>> -I../os/default -I/usr/include -I/usr/include/X11 ../force.c
>>>>> ../force.c: In function 'forcePVUpdateFields':
>>>>> ../force.c:1028: error: 'YES' undeclared (first use in this function)
>>>>> ../force.c:1028: error: (Each undeclared identifier is reported only
>>>>> once
>>>>> ../force.c:1028: error: for each function it appears in.)
>>>>> make[2]: *** [force.o] Error 1
>>>>> make[2]: Leaving directory
>>>>> `/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
>>>>> make[1]: *** [install.linux-x86_64] Error 2
>>>>> make[1]: Leaving directory
>>>>> `/users/thomas/epics/extensions/src/alh1_2_24'
>>>>> make: *** [alh1_2_24.install] Error 2
>>>>> Thank you,
>>>>> Patrick
Best Regards
Chen
Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
| www.sinap.ac.cn
- Re: alarm handler on base 3-14-11 Patrick Thomas
- alarm handler on base 3-14-11 Patrick Thomas
- RE: alarm handler on base 3-14-11 Mark Rivers
- Re: alarm handler on base 3-14-11 Zhichu Chen
Re: alarm handler on base 3-14-11 Matthieu Bec
<2009>
2025
2026
<2009>
2025
2026
