1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel access and ca_element_count
To: [email protected]
Date: Mon, 5 Oct 2009 22:54:33 +0200
On Montag, 5. Oktober 2009, Andrew Johnson wrote:
> On Monday 05 October 2009 10:24:25 Jeff Hill wrote:
> > In the short term:
> > Clients _are_ currently allowed to _not_ specify the element count when
> > they subscribe (they can specify an element count of zero). So perhaps
> > the CA code should be changed allowing the array length to be dynamic
> > in just that situation. Currently, we are locking the element count for
> > that situation to what was there when the channel connects, but perhaps
> > this is wrong (lazy) etc. Any opinions from Andrew or others?
> I agree with Michael in favor of changing the behavior so that when a
> client specifies COUNT=0 in its subscription, it is requesting a dynamic
> element count such that successive events may have different numbers of
> elements. However it should never be given more than ca_element_count()
> elements so it can always use that number to allocate data storage at
> connection time.  If at some time in the future we want to make it
> possible for even that number to be increased, this could be indicated to
> the client by a pair of disconnect/ reconnect events.
I would be very happy if something like this could be done at the database
level i.e. for pv links between records.
Cheers
Ben
Re: Channel access and ca_element_count Andrew Johnson
Channel access and ca_element_count michael.abbott
RE: Channel access and ca_element_count Jeff Hill
Prev: Re: state notation code flags Benjamin Franksen
Next: RE: Channel access dynamic array subscription update element count Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel access and ca_element_count Andrew Johnson
Next: Re: Channel access and ca_element_count Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
