1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel access and ca_element_count
To: [email protected]
Date: Tue, 6 Oct 2009 17:20:29 -0500
Hi Ben,
On Monday 05 October 2009 15:54:33 Benjamin Franksen wrote:
> On Montag, 5. Oktober 2009, Andrew Johnson wrote:
> > I agree with Michael in favor of changing the behavior so that when a
> > client specifies COUNT=0 in its subscription, it is requesting a dynamic
> > element count such that successive events may have different numbers of
> > elements. However it should never be given more than ca_element_count()
> > elements so it can always use that number to allocate data storage at
> > connection time.  If at some time in the future we want to make it
> > possible for even that number to be increased, this could be indicated to
> > the client by a pair of disconnect/ reconnect events.
> I would be very happy if something like this could be done at the database
> level i.e. for pv links between records.
I agree we should implement this for PV links, but I don't want to break
applications that might rely on the existing behavior (can you remember what
happens right now, do both DB and CA links zero-fill the elements beyond the
current element count?).  We should probably add a new link flag to enable
dynamic sizing.
I've added this to my To Do list.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Channel access and ca_element_count Benjamin Franksen
Channel access and ca_element_count michael.abbott
Re: Channel access and ca_element_count Andrew Johnson
Prev: RE: Roper Quad-RO locks up with areaDetector/ccd apps Ru Igarashi
Next: Re: Channel access and ca_element_count Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel access and ca_element_count Benjamin Franksen
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
