1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Incorrect get_precision
To: tech-talk <[email protected]>
Date: Mon, 19 Oct 2009 11:38:45 +0200
Hi all,
I found that the get_precision function is not correct in the following records:
- calc
- calcout
- dfanout
My change in the calc record (3.14.10) (similar for others):
163,167c163,167
<     if (paddr->pfield == (void *)&pcalc->val) {
<       *pprecision = pcalc->prec;
<     } else {
<       recGblGetPrec(paddr, pprecision);
>       return 0;
The function recGblGetPrec does only limit the precision to [0,15] if the type is float or double. Setting is done only for integer types. The result of the old code was a zero-precision display of non-VAL fields. This change is necessary for Epics 3.14.11, too.
- Bernd
Prev: Re: StripTool build errors: SDDS.h? Janet
Next: Bug in asyn 4-7 and up ?? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn messages Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
