On Oct 19, 2009, at 4:05 AM, [email protected] wrote:
Hi Eric,
last week I was going to switch from asyn 4-6 to asyn 4-10 and I run
into a problem with an IEEE- device.
This device uses a simple linefeed char to terminate a reply and
does not use the EOI line.
And here is where the problem occurred: Reading a reply from the
device makes the softIOC crash.
Some debugging and reading the code revealed that it crashes in line
413 of function readIt (file asynGpib.c)
*eomReason |= ASYN_EOM_EOS; (This line was added in
release 4-7 for the first time)
Nothing wrong with that code, but the calling function, which is
gpibRead (file devSupportGpib.c), does not
pass a proper address for eomReason:
status = pasynOctet->read(asynOctetPvt,pasynUser,pgpibDpvt-
>msg,pgpibCmd->msgLen,&nchars,0);
I have changed this in my local copy to:
>msg,pgpibCmd->msgLen,&nchars,&eomReason);
and now I can read the device without problems.
I have attached my versions of asynGpib.c and devSupportGpib.c,
please check them and if you agree,
put them into the next release.
BTW.: We are using epicsRelease 3.14.10, softIOC runnung under Suse
linux 10.2
I made a slightly different change to fix this problem. Please apply
the following to asyn/asynGpib/asynGpib.c
Index: asyn/asynGpib/asynGpib.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/asyn/asyn/
asynGpib/asynGpib.c,v
retrieving revision 1.43
diff -u -r1.43 asynGpib.c
--- asyn/asynGpib/asynGpib.c 28 May 2008 18:58:50 -0000 1.43
+++ asyn/asynGpib/asynGpib.c 19 Oct 2009 13:48:51 -0000
@@ -410,12 +410,12 @@
if(status!=asynSuccess) return status;
if(pgpibPvt->eoslen==1 && nt>0) {
if(data[nt-1]==pgpibPvt->eos) {
- *eomReason |= ASYN_EOM_EOS;
+ if (eomReason) *eomReason |= ASYN_EOM_EOS;
nt--;
if(nt<maxchars) data[nt] = 0;
- if(nt==maxchars) *eomReason |= ASYN_EOM_CNT;
+ if((nt==maxchars) && eomReason) *eomReason |= ASYN_EOM_CNT;
*nbytesTransfered = (size_t)nt;
pasynOctetBase->callInterruptUsers(pasynUser,pgpibPvt->pasynPvt,
data,nbytesTransfered,eomReason);
My apologies for introducing this bug, which has been present since
2006-07-17 (and thus is present in asyn R4-7 through R4-12).
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Incorrect get_precision Schoeneburg, Bernd
RE: EPICS build for MVME3100 Lawrence T. Hoff
<2009>
2025
2026
genSub and synApps 5_4_1 Emmanuel Mayssat
<2009>
2025
2026
