I just checked my MV3100 build environment for VxWorks
5.5.1. I use :
Ccppc -mcpu=8540 -msoft-float -mspe=no -mabi=no-spe -DCPU=PPC85XX ...
It *is* a "special" compiler:
$ccppc -v
Reading specs from ../lib/gcc-lib/powerpc-wrs-vxworks/3.3-e500/specs
Configured with: /wind/river/host/src/gnu.e500/configure --with-headers=yes
--srcdir=/wind/river/host/src/gnu.e500
--prefix=/wind/river/host/gnu/3.3/sun4-solaris2 --target=powerpc-wrs-vxworks
--enable-languages=c,c++
Thread model: vxworks
gcc version 3.3-e500 20030421 (Wind River)
Compared with MV2100:
$ccppc -v
Reading specs from ../lib/gcc-lib/powerpc-wrs-vxworks/gcc-2.96/specs
gcc version gcc-2.96 (2.96+) 19990621 AltiVec VxWorks 5.5
HTH -- Larry
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Ron Sluiter
> Sent: Thursday, October 15, 2009 1:01 PM
> To: William F. Steele
> Cc: [email protected]
> Subject: Re: EPICS build for MVME3100
> Hello William,
> According to this WRS web page;
> http://www.windriver.com/products/bsp_web/bsp_architecture.html?archite
> cture=PowerPC
> it does not look like the MVME3100 is supported with Tornado 2.2.1.
> Ron
> William F. Steele wrote:
> > I don't understand how to build EPICS for MVME3100. I have no problem
> > with mcp750, mvme2100, 68040, or 68060. I am trying to build EPICS
> > 3.14.11 and am using vxWorks 5.5.1 with Tornado 2.2.1. If I put
> > vxWorks-mpc8540 in my list of CROSS_COMPILER_TARGET_ARCHS, I get
> > compile errors which I traced to ARCH_DEP_CPPFLAGS which is set to
> > -DCPU=PPC32 which the compiler does not recognize. If I change that
> to
> > ARCH_DEP_CPPFLAGS = -DCPU=PPC85XX, then I no longer get compile
> > errors, but EPICS will not load due to a lot of undefined symbols. I
> > talked to WRS about this problem and was advised that I was using the
> > wrong compiler. When I use Tornado to build vxWorks, Tornado uses
> > /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/gnu/3.3/sun4-
> solaris2/bin/ccppc,
> > but when building EPICS, the EPICS build system uses
> > /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/sun4-
> solaris2/bin/ccppc,
> > so, apparently, the EPICS build system does not automatically setup
> to
> > use the correct tools when specifying the target
> > vxWorks-mpc8540. What needs to be done to make this work right?
> Thanks.
- Re: EPICS build for MVME3100 Andrew Johnson
- EPICS build for MVME3100 William F. Steele
- Re: EPICS build for MVME3100 Ron Sluiter
Bug in asyn 4-7 and up ?? Eric Norum
<2009>
2025
2026
RE: EPICS build for MVME3100 Erik Johansson
<2009>
2025
2026
