1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: devLibOSD.c for Linux
To: Mi Qingru <[email protected]>
Cc: epics tech-talk <[email protected]>
Date: Fri, 23 Oct 2009 16:20:23 +0200
Mi Qingru wrote:
> hi,
> Base-3.14.8.2 and base-3.14.11 only support devLib.c on vxWorks and
> RTEMS. How to use the routines in devLib.c for Linux?
> Mi Qingru
> 2009-10-22
You simply have to write them :-)
Most of the routines refer to VME bus. They probably don't make much sense on an
ordinary Linux PC. But there might actually be some Linux based VME systems.
However it seems that nobody has used such systems so far. It's like everything
in EPICS: The first one who needs a feature has to implement it.
Good luck and tell us when you're done :-)
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: devLibOSD.c for Linux Mark Rivers
devLibOSD.c for Linux Mi Qingru
Prev: Re: compiling streamDevice with CALC set fails Dirk Zimoch
Next: RE: devLibOSD.c for Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: devLibOSD.c for Linux Mi Qingru
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
