1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: devLibOSD.c for Linux
To: "Dirk Zimoch" <[email protected]>, "Mi Qingru" <[email protected]>
Cc: epics tech-talk <[email protected]>
Date: Fri, 23 Oct 2009 09:46:51 -0500
I don't think this is true.  The Canadian Light Source and the
Australian Synchrotron are using Linux with VME via the SIS PCI to VME
bridge.  I believe there is a version of devLib that supports this.
They are using a recent version of the IPAC module for VME Industry Pack
modules, and I believe IPAC uses devLib.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: Friday, October 23, 2009 9:20 AM
To: Mi Qingru
Cc: epics tech-talk
Subject: Re: devLibOSD.c for Linux
Mi Qingru wrote:
> hi,
> Base-3.14.8.2 and base-3.14.11 only support devLib.c on vxWorks and
> RTEMS. How to use the routines in devLib.c for Linux?
> Mi Qingru
> 2009-10-22
You simply have to write them :-)
Most of the routines refer to VME bus. They probably don't make much
sense on an
ordinary Linux PC. But there might actually be some Linux based VME
systems.
However it seems that nobody has used such systems so far. It's like
everything
in EPICS: The first one who needs a feature has to implement it.
Good luck and tell us when you're done :-)
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: devLibOSD.c for Linux Andrew Johnson
devLibOSD.c for Linux Mi Qingru
Re: devLibOSD.c for Linux Dirk Zimoch
Prev: Re: devLibOSD.c for Linux Dirk Zimoch
Next: RE: compiling streamDevice with CALC set fails Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: devLibOSD.c for Linux Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
