1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: devLibOSD.c for Linux
To: [email protected]
Date: Fri, 23 Oct 2009 10:35:50 -0500
On Friday 23 October 2009 09:46:51 Mark Rivers wrote:
> I don't think this is true.  The Canadian Light Source and the
> Australian Synchrotron are using Linux with VME via the SIS PCI to VME
> bridge.  I believe there is a version of devLib that supports this.
> They are using a recent version of the IPAC module for VME Industry Pack
> modules, and I believe IPAC uses devLib.
Actually devLib has supported the ability to write your own support routines
for devLib since soon after the CLS & AS started using the SIS bridge.  There
is a global function table which they (or anyone else can) implement and link
into an IOC and which is then used to provide *most* of the operations.
Unfortunately a parallel change to devLib was merged a few years ago which
means that some of the devLib functions do not go through the function table;
I'm hoping Michael Davidsaver's rewrite of devLib will fix this issue once and
for all, but it will probably require that the external driver(s) be updated.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: devLibOSD.c for Linux Davidsaver, Michael
devLibOSD.c for Linux Mi Qingru
Re: devLibOSD.c for Linux Dirk Zimoch
RE: devLibOSD.c for Linux Mark Rivers
Prev: RE: compiling streamDevice with CALC set fails Mark Rivers
Next: RE: devLibOSD.c for Linux Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: devLibOSD.c for Linux Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
