1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: File I/O from genSub Process function
Cc: [email protected]
Date: Mon, 02 Nov 2009 16:38:37 -0800
Thanks for the suggestion.
I can't risk trying anything till our next down time on Wed,
but I'll give it a try then.
- Bruce
Andrew Johnson wrote:
Hi Bruce,
On Friday 30 October 2009 18:41:33 Bruce Hill wrote:
I have a genSub I've setup to run test code on my IOC, and I'm getting
errors when I try to read the test set data files.    This is an RTEMS
4.7.1 based
IOC accessing an NFS mounted filesystem.     I'm able to read the same
files from a genSub Init function, but not from the Process function.
I can also read these files if I initiate the test from the Cexp shell
on the RTEMS console.
Is there something about how the Process functions are called that would
preclude file I/O?
No, although file I/O is blocking and as such will cause whatever scan thread
is processing that record to be delayed and could affect whatever control
algorithms the IOC is running at the time.  We usually suggest that the best
way to do file I/O inside the IOC is in a SNL program which can block whenever
it likes and talk to the PVs using CA, or even global variables (provided you
understand the need to lock them).
I suspect the issue might be due to the fact that NFS can take up quite a lot
of stack space - can you check whether the relevent thread has gone over its
allotted stack?
- Andrew
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 94
Menlo Park, CA  94025
File I/O from genSub Process function Bruce Hill
Re: File I/O from genSub Process function Andrew Johnson
Prev: Re: File I/O from genSub Process function Andrew Johnson
Next: Re: File I/O from genSub Process function Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
