About a month ago we had a long and interesting conversation about
alternative Python channel access bindings, and I see that the topic of Qt
bindings has now come up: I'd like to point out that cothread also
provides PyQt and CA integration.
I've tried to take account of the easy fixes to cothread.catools arising
from our earlier discussions, including a number of bug fixes and
suggestions, and I offer a 1-15 cothread release, which can be downloaded
from
http://controls.diamond.ac.uk/downloads/python/cothread/
Forgive me: this release is not thorougly tested, I wanted to make it
visible sooner rather than later.
So what's new in this release?
1. Fixed some interesting bugs on 64-bit Linux observed by Juan Guzman.
This was mostly a matter of getting the ctypes definitions right. I've
also tried to ensure that the automatic conversions work properly on
64-bit systems, but this needs more testing.
2. Added support for four somewhat cryptic DBR_ features:
DBR_STSACK_STRING, DBR_CLASS_NAME (caget & camonitor only) and
DBR_PUT_ACKT, DBR_PUT_ACKS (caput only). Easy enough to implement, so
they're there in case they're useful.
3. Added support for automatically converting between arrays of char and
strings: this is implemented through a new "fake" DBR_CHAR_STR value which
triggers some special case processing.
4. Added option for DBE_PROPERTY monitoring.
5. caget([]) no longer causes an exception, instead an empty list is
returned (and similarly for the other functions).
6. Channel properties can now be interrogated, by calling
info = connect(pv,cainfo=True) and inspecting or printing info.
7. The implementation of input_hook._readline_hook() has been rather
drastically simplified. This may have uncomfortable side effects...
You'll find the detailed documentation of the catools API at
http://controls.diamond.ac.uk/downloads/python/cothread/1-15/docs/catools.html
I offer cothread.catools as a fully featured and easy to use channel
access library, but I understand that the cothread underpinnings can be
controversial. I am aware of existing weaknesses, and I'd like to work on
improving things. Here are my thoughs of areas that need more work:
1. Packaging of the cothread library is rather horrible. To actually use
this, the first thing you need to do is edit line 55 of cothread/cadef.py
to point to your own libca.so. I'd welcome a better packaging!
2. The underlying coroutine mechanism is based on greenlets which work by
reusing the common stack by copying stack frames to and from the heap.
I'm not happy with this, in particular it breaks polling with timers with
Qt4 (so a different polling mechanism is used). This needs closer
examination.
3. Is it possible, perhaps, to decouple cothread.catools from cothreads
altogether? I'm not sure about this, as I make some essential use of
coding tricks that only cothreads allow, but it could be worth a closer
look.
4. Framework integration needs to be more developed. At the moment Qt,
readline and CA integration are present and work well enough, but things
could be done more smoothly, and other probably other framework
integrations would be useful.
5. Control-C handling ... um ... needs work. Unfortunately Python's
(default?) handling of control-C is bad news anyway: injecting exceptions
into code which never otherwise sees them is a recipe for Heisenbugs!
Re: QtCATool Steven M. Hartman
RE: Next generation EPICS display manager Dalesio, Leo
<2009>
2025
2026
Re: FW: Next generation EPICS display manager Zhichu Chen
Re: Qt edm John William Sinclair
<2009>
2025
2026
