1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA problem w EPICS 3.14.11 & VxWorks 6.7
To: "Jeff Hill" <[email protected]>
Cc: "'GOURNAY Jean-Francois'" <[email protected]>, [email protected]
Date: Wed, 25 Nov 2009 17:13:20 +0900
Hello Jean-Francois, hello Jeff,
If I understand the issue correctly, I think it lies in the network
interface handling, and we need to tweak the EPICS build script for
vxWorks-6.7.  (We've never used vxWorks-6 other than 6.7.)  The
same occurred in R3.14.10.
Unless we use "-DBSD=44" for osdSock.h, incorrect network interface
structure is assumed, and an incorrect list of interfaces is
constructed, then the EPICS_CA_{,AUTO_}ADDR_LIST behavior becomes
wrong.
For example, we use these variables in
CONFIG_SITE.Common.vxWorksCommon to build R3.14.11 for vxWorks-6.7.
BSD_DEFINE_VERSION_6.7 = -DBSD=44
OP_BSD_DEFINE = $(BSD_DEFINE_VERSION_$(VXWORKS_VERSION))
VXWORKS_VERSION = 6.7
VX_GNU_VERSION_6.7 = 4.1.2
OP_SYS_CPPFLAGS += -DvxWorks $(OP_BSD_DEFINE)
OP_SYS_CFLAGS += -fno-builtin $(OP_BSD_DEFINE)
WORKBENCH_VERSION = 3.1
I'm sorry that I forgot to report this, although this was found by
Tomohiro Okazaki before ICALEPCS09.
Cheers, Kazuro.
>>> On Tue, 24 Nov 2009 10:14:56 ,  "Jeff Hill" <[email protected]> wrote;
> I had a quick look at what has changed between R3.14.10 and R3.14.11 WRT
> EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST. I do see that in
> R3.14.11
> Mantis 331 was fixed. This is certainly a relevant change, but I don't
> at
> this time expect the side effect that you are observing.
> o  This problem arises also with CA links between VxWorks an Linux.
> o  On the other hand, no problem with CA links between 2 Linux IOCs
> The above might be a very useful bit of information. Presumably the same
> vxWorks version, vxWorks 6.7, was also used with R3.14.10? Frequently
> vxWorks systems boot by default with routes limiting access only to the
> local subnet. If a EPICS system is operating in a WAN environment it may
> be
> necessary to configure routes into the vxWorks system which enable a
> vxWorks
> based CA server to respond to requests originating outside it's subnet.
> These routing restrictions might also apply to vxWorks based CA clients
> communicating with off subnet servers. See "routeLib" in the vxWorks
> reference manual.
> Of course, the other difference between vxWorks and Linux in your
> situation
> might be PPC (big-endian) versus Intel (little-endian), and that might
> imply
> a missing byte swap in the CA code, but I haven't identified one at
> this
> time based on the source code differences.
> o  We have "CA beacon routing ... ECONNREFUSED" on the 1st booted
> IOC.
> This indicates that the IOC is unable to identify a route for a beacon
> message. A list of addresses is also configured for the beacons. When
> EPICS_CA_AUTO_ADDR_LIST is YES, please type 'casr <integer interest
> level>'
> and send the result. This will reveal what the address list is being set
> to
> at higher interest levels. One can also receive an overwhelming amount
> of
> information by typing 'dbcar "record name", <integer interest
> level>'. At
> some higher interest level you should see also the CA address list for
> the
> db ca client. You might also try 93routeShow94 on this vxWorks system.
> If
> there is a problem with auto configuring the client92s address list we
> should
> see clear evidence in this diagnostic.
> With the above information, fault isolation should proceed quickly, and
> maybe I won92t need to spend as much time staring at the source code.
> Thanks for your help,
> Jeff
> ______________________________________________________
> Jeffrey O. Hill           Email         <mailto:[email protected]>
> [email protected]
> LANL MS H820              Voice        505 665 1831
> Los Alamos NM 87545 USA   FAX          505 665 5107
> Message content: TSPA
> From: [email protected]
> [mailto:[email protected]]
> On Behalf Of GOURNAY Jean-Francois
> Sent: Tuesday, November 24, 2009 7:38 AM
> To: [email protected]
> Subject: CA problem w EPICS 3.14.11 & VxWorks 6.7
> Hello,
> We have 2 IOCs running EPICS 3.14.11 with VxWorks 6.7.
> Any record on an IOC with a CA link on a record located in the other IOC
> stays UDF=1 forever. This problem arises with
> EPICS_CA_AUTO_ADDR_LIST= YES.
> With EPICS_CA_AUTO_ADDR_LIST=NO and EPICS-CA-ADDR-LIST= ... it
> works. But we
> would like to avoid to have this parameter to "NO" and having to
> maintain
> the host list in ADDR-LIST.
> Especially in the case where:
> On IOC1 : EPICS-CA-ADDR-LIST=<IP IOC2>
> And on IOC2: EPICS-CA-ADDR-LIST=<IP IOC1>
> (needed for CA links in both directions)
> We have "CA beacon routing ... ECONNREFUSED" on the 1rst booted IOC.
> We did'nt have this problem with the previous release.
> Thanks Jeff (I think it is probably a problem for you . . .)
> J.F. Gournay
> CEA Saclay
> IRFU/SIS
Kazuro FURUKAWA <[email protected]>
 Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
 Telephone: +81-29-864-5200 x4316,  Facsimile: +81-29-864-0321
RE: CA problem w EPICS 3.14.11 & VxWorks 6.7 Jeff Hill
Prev: (Another) Modbus problem Stephen Lewis
Next: RE: Modbus help emma.shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA problem w EPICS 3.14.11 & VxWorks 6.7 Jeff Hill
Next: RE: CA problem w EPICS 3.14.11 & VxWorks 6.7 GOURNAY Jean-Francois
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
