1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA problem w EPICS 3.14.11 & VxWorks 6.7
To: "Jeff Hill" <[email protected]>, <[email protected]>, "Kazuro FURUKAWA" <[email protected]>
Date: Wed, 25 Nov 2009 11:28:00 +0100
Hello Jeff, hello Kazuro
Thanks for your replies.
Jeff,
I have included the trace of the 2 following commands  :
Dbcar “VMETST-CA-O”, “2”
Casr “1”
Before these commands, I did a dbtr “VMETST-CA-O”, surprisingly UDF becomes 0 but the value (supposed to be retrieved through a CA link to VMETST) is 0 (it should be “223”).
Both VxWorks IOCs are on the same network (132.166.33.10 and 132.166.33.11)
Kazuro,
I will pass the information to my colleague in charge of the VxWorks support. He had already a lot of trouble with the IP stack of the new release of VxWorks (2nd Ethernet port of our MVME5500 not working, problem of connection with rlogin, problem with connect function of socket.h). Recompiling with gnu instead of diab helps for some point (wancomEnd.c) but there are still pending problems.
J.F. Gournay
CEA Saclay
IRFU/SIS
De : Jeff Hill [mailto:[email protected]]
Envoyé : mardi 24 novembre 2009 18:15
À : GOURNAY Jean-Francois; [email protected]
Objet : RE: CA problem w EPICS 3.14.11 & VxWorks 6.7
Hello Jean-Francois,
I had a quick look at what has changed between R3.14.10 and R3.14.11 WRT EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST. I do see that in R3.14.11 Mantis 331 was fixed. This is certainly a relevant change, but I don’t at this time expect the side effect that you are observing.
Ø       This problem arises also with CA links between VxWorks an Linux.
Ø       On the other hand, no problem with CA links between 2 Linux IOCs
The above might be a very useful bit of information. Presumably the same vxWorks version, vxWorks 6.7, was also used with R3.14.10? Frequently vxWorks systems boot by default with routes limiting access only to the local subnet. If a EPICS system is operating in a WAN environment it may be necessary to configure routes into the vxWorks system which enable a vxWorks based CA server to respond to requests originating outside it's subnet. These routing restrictions might also apply to vxWorks based CA clients communicating with off subnet servers. See "routeLib" in the vxWorks reference manual.
Of course, the other difference between vxWorks and Linux in your situation might be PPC (big-endian) versus Intel (little-endian), and that might imply a missing byte swap in the CA code, but I haven’t identified one at this time based on the source code differences.
Ø       We have “CA beacon routing … ECONNREFUSED” on the 1st booted IOC.
This indicates that the IOC is unable to identify a route for a beacon message. A list of addresses is also configured for the beacons. When EPICS_CA_AUTO_ADDR_LIST is YES, please type ‘casr <integer interest level>’ and send the result. This will reveal what the address list is being set to at higher interest levels. One can also receive an overwhelming amount of information by typing ‘dbcar “record name”, <integer interest level>’. At some higher interest level you should see also the CA address list for the db ca client. You might also try “routeShow” on this vxWorks system. If there is a problem with auto configuring the client’s address list we should see clear evidence in this diagnostic.
With the above information, fault isolation should proceed quickly, and maybe I won’t need to spend as much time staring at the source code.
Thanks for your help,
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
From: [email protected] [mailto:[email protected]] On Behalf Of GOURNAY Jean-Francois
Sent: Tuesday, November 24, 2009 7:38 AM
To: [email protected]
Subject: CA problem w EPICS 3.14.11 & VxWorks 6.7
Hello,
We have 2 IOCs running EPICS 3.14.11 with VxWorks 6.7.
Any record on an IOC with a CA link on a record located in the other IOC stays UDF=1 forever. This problem arises with EPICS_CA_AUTO_ADDR_LIST= YES.
With EPICS_CA_AUTO_ADDR_LIST=NO and EPICS-CA-ADDR-LIST= … it works. But we would like to avoid to have this parameter to “NO” and having to maintain the host list in ADDR-LIST.
Especially in the case where:
On IOC1 : EPICS-CA-ADDR-LIST=<IP IOC2>
And on IOC2: EPICS-CA-ADDR-LIST=<IP IOC1>
(needed for CA links in both directions)
We have “CA beacon routing … ECONNREFUSED” on the 1rst booted IOC.
We did’nt have this problem with the previous release.
Thanks Jeff (I think it is probably a problem for you . . .)
J.F. Gournay
CEA Saclay
IRFU/SIS
sigvm11->
sigvm11->dbtr "VMETST-CA-O"
ACKS: INVALID       ACKT: YES           ADEL: 0             ALST: 0
AOFF: 0             ASG:                ASLO: 0             BKPT: 00
DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DOL:CA_LINK VMETST CA NMS               DRVH: 0
DRVL: 0             DTYP: Soft Channel  EGU:                EGUF: 0
EGUL: 0             EOFF: 0             ESLO: 1             EVNT: 0
FLNK:CONSTANT 0     HHSV: NO_ALARM      HIGH: 0             HIHI: 0
HOPR: 0             HSV: NO_ALARM       HYST: 0             INIT: 0
IVOA: Continue normally                 IVOV: 0             LALM: 0
LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSV: NO_ALARM
MDEL: 0             MLST: 0             NAME: VMETST-CA-O   NSEV: NO_ALARM
NSTA: NO_ALARM      OIF: Full           OMOD: 0             OMSL: closed_loop
ORAW: 0             ORBV: 0             OROC: 0             OUT:CONSTANT
OVAL: 0             PACT: 0             PHAS: 0             PINI: NO
PREC: 0             PRIO: LOW           PROC: 0             PUTF: 0
PVAL: 0             RBV: 0              ROFF: 0             RPRO: 0
RVAL: 0             SCAN: Passive       SDIS:CONSTANT       SEVR: INVALID
SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT
STAT: LINK          TIME: 2009-11-25 11:05:56.218660126     TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 0              VAL: 0
value = 0 = 0x0
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->dbcar "VMETST-CA-O","2"
CA links in record named 'VMETST-CA-O'
                 VMETST-CA-O.DOL  --> VMETST                        (0, 0)
Total 1 CA link; 0 connected, 1 not connected.
    0 can't read, 0 can't write.  (0 disconnects, 0 writes prohibited)
ca_client_context at 0x6d2f20 pndRecvCnt=0 ioSeqNo=0
dbContext at 0x6d3250
        event call back cache location 0x0, and its size 0
dbContextReadNotifyCache
dbContextReadNotifyCacheAlocator
        count 0 and size 0
epicsMutexId 0x6d3070 source ../../../src/libCom/osi/epicsMutex.cpp line 224
Semaphore Id        : 0x6d2ff0
Semaphore Name      : N/A
Semaphore Type      : MUTEX
Task Queuing        : PRIORITY
Pended Tasks        : 0
Owner               : 0x702880     (tShell0)
Options             : 0xd       SEM_Q_PRIORITY
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Registered Task     : NONE
Event(s) to Send    : N/A
Options             : N/A
Channel Access Client Context at 0x623140 for user vw
        revision "@(#) EPICS 3.14.11, CA Client Library Nov  5 2009"
Hash table with 0 buckets and 0 items of type 6tcpiiu installed
        connection time out watchdog period 30.000000
Datagram IO circuit (and disconnected channel repository)
        repeater port 5065
        default server port 5064
Channel Access Address List
localhost:5064
        socket identifier 21
        bytes in xmit buffer 16
        shut down command bool 0
        recv thread exit signal:
repeater subscribe timer: attempts=2 registered=1 once=0
disconnect governor timer: with 0 channels pending
searchTimer with period 0.032000
channels with search request pending = 0
channels with search response pending = 0
searchTimer with period 0.064000
searchTimer with period 0.128000
searchTimer with period 0.256000
searchTimer with period 0.512000
searchTimer with period 1.024000
searchTimer with period 2.048000
searchTimer with period 4.096000
searchTimer with period 8.192000
searchTimer with period 16.384000
searchTimer with period 32.768000
searchTimer with period 65.536000
searchTimer with period 131.072000
channels with search response pending = 3
Channel "VMETST" is disconnected
        network IO pointer = 0x839930
        server identifier 4294967295
        search retry number=17
        name length=7
        name length=7
Channel "ASGVAL" is disconnected
        name length=7
searchTimer with period 262.144000
Program begin time:
epicsTime: WED NOV 25 2009 11:01:29.920030178
epicsTime: revision "@(#) EPICS 3.14.11, Common Utilities Library Nov  5 2009"
Channel identifier hash table:
Hash table with 512 buckets and 3 items of type 4nciu installed
        name length=7
        name length=7
        name length=7
        name length=7
        name length=7
        name length=7
entries per bucket: mean = 0.005859 std dev = 0.076322 max = 1
509 empty buckets
IO identifier hash table:
Hash table with 0 buckets and 0 items of type 8baseNMIU installed
Beacon source identifier hash table:
Hash table with 512 buckets and 10 items of type 3bhe installed
CA beacon hash entry for 132.166.14.59:41499 with period estimate 15.000716
        beacon number 179, on WED NOV 25 2009 11:06:04
CA beacon hash entry for 132.166.31.217:5064 with period estimate 15.002840
        beacon number 132882, on WED NOV 25 2009 11:06:01
CA beacon hash entry for 132.166.35.171:5064 with period estimate 29.999938
        beacon number 0, on WED NOV 25 2009 11:05:39
CA beacon hash entry for 132.166.35.172:5064 with period estimate 30.959020
        beacon number 0, on WED NOV 25 2009 11:05:43
CA beacon hash entry for 132.166.35.160:5064 with period estimate 15.000000
        beacon number 0, on WED NOV 25 2009 11:06:03
CA beacon hash entry for 132.166.35.185:5064 with period estimate 30.934866
        beacon number 0, on WED NOV 25 2009 11:05:42
CA beacon hash entry for 132.166.35.190:5064 with period estimate 5.042589
        beacon number 0, on WED NOV 25 2009 11:06:04
CA beacon hash entry for 132.166.35.181:5064 with period estimate 30.941204
        beacon number 0, on WED NOV 25 2009 11:05:58
CA beacon hash entry for 192.168.1.1:5064 with period estimate 15.000000
        beacon number 28057, on WED NOV 25 2009 11:06:00
CA beacon hash entry for 132.166.14.59:5064 with period estimate 15.000626
entries per bucket: mean = 0.019531 std dev = 0.138383 max = 1
502 empty buckets
Timer queue:
EPICS threaded timer queue at 0x70a690
epicsThread at 0x838300
  NAME         ENTRY       TID    PRI   STATUS      PC       SP     ERRNO  DELAY
timerQueue  9e5470         838300 148 PEND+T       27c2d0   838180  3d0004     1
epicsTimerQueue with 15 items pending
timer, state = pending, delay = 0.019667
timer, state = pending, delay = 0.022333
timer, state = pending, delay = 0.023667
timer, state = pending, delay = 0.097667
timer, state = pending, delay = 0.337000
timer, state = pending, delay = 0.432333
timer, state = pending, delay = 0.825000
timer, state = pending, delay = 1.673000
timer, state = pending, delay = 3.721000
timer, state = pending, delay = 7.783667
timer, state = pending, delay = 15.725667
timer, state = pending, delay = 15.726334
timer, state = pending, delay = 48.494334
timer, state = pending, delay = 114.030334
        name length=7
        name length=7
        name length=7
timer, state = pending, delay = 245.119001
reschedule event
Semaphore Id        : 0x623c50
Semaphore Type      : BINARY
Task Queuing        : FIFO
Pended Tasks        : 1
State               : EMPTY
Options             : 0x0       SEM_Q_FIFO
VxWorks Events
Options             : N/A
Pended Tasks
   NAME      TID    PRI TIMEOUT
timerQueue   838300 148       1
exit event
Semaphore Id        : 0x623cd0
Task Queuing        : FIFO
Pended Tasks        : 0
State               : EMPTY
VxWorks Events
Options             : N/A
exitFlag = F, terminateFlag = F
IP address to name conversion engine:
ipAddrToAsciiEngine at 0x7afea0 with 0 requests pending
mutex:
epicsMutexId 0x7b0440 source ../../../src/libCom/osi/epicsMutex.cpp line 224
Semaphore Id        : 0x7b03c0
Pended Tasks        : 0
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Options             : N/A
laborEvent:
Semaphore Id        : 0x7b0470
Task Queuing        : FIFO
Pended Tasks        : 1
State               : EMPTY
VxWorks Events
Options             : N/A
Pended Tasks
ipToAsciiProxy  7b5d10 189       0
exitFlag  boolean = 0
exit event:
Default mutex:
Pended Tasks        : 0
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Options             : N/A
mutex:
Pended Tasks        : 0
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Options             : N/A
        preemptive callback is enabled
        there are 0 unsatisfied IO operations blocking ca_pend_io()
        the current io sequence number is 0
IO done event:
Semaphore Id        : 0x6d3150
Task Queuing        : FIFO
Pended Tasks        : 0
State               : EMPTY
VxWorks Events
Options             : N/A
Synchronous group identifier hash table:
Hash table with 0 buckets and 0 items of type 4CASG installed
value = 0 = 0x0
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->
sigvm11->casr "1"
Channel Access Server V4.11
No clients connected.
UDP Server:
UDP 132.166.35.181:1029(): User="", V4.0, 0 Channels, Priority=0
        Task Id=0x817900, Socket FD=29
        Secs since last send 366.52, Secs since last receive   0.03
        Unprocessed request bytes=16, Undelivered response bytes=0
        State=up
        180 bytes allocated
        Send Lock
epicsMutexId 0x81cc20 source ../caservertask.c line 732
Semaphore Id        : 0x81cba0
Pended Tasks        : 0
Owner               : NONE
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Options             : N/A
        Put Notify Lock
epicsMutexId 0x81ccd0 source ../caservertask.c line 733
Semaphore Id        : 0x81cc50
Pended Tasks        : 0
Owner               : NONE
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Options             : N/A
        Address Queue Lock
epicsMutexId 0x81cd80 source ../caservertask.c line 734
Semaphore Id        : 0x81cd00
Pended Tasks        : 0
Owner               : NONE
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Options             : N/A
        Event Queue Lock
epicsMutexId 0x81ce30 source ../caservertask.c line 735
Semaphore Id        : 0x81cdb0
Pended Tasks        : 0
Owner               : NONE
                                SEM_DELETE_SAFE
                                SEM_INVERSION_SAFE
VxWorks Events
Options             : N/A
        Block Semaphore
Semaphore Id        : 0x81cb20
Task Queuing        : FIFO
Pended Tasks        : 0
State               : EMPTY
VxWorks Events
Options             : N/A
There are currently 1260 bytes on the server's free list
7 client(s), 0 channel(s), 0 event(s) (monitors) 0 putNotify(s)
0 small buffers (16384 bytes ea), and 0 jumbo buffers (16408 bytes ea)
The server's resource id conversion table:
Bucket entries in use = 0 bytes in use = 16404
Bucket entries/hash id - mean = 0.000000 std dev = 0.000000 max = 0
The server's array size limit is 16408 bytes max
value = 28 = 0x1c
Re: CA problem w EPICS 3.14.11 & VxWorks 6.7 Kazuro FURUKAWA
RE: CA problem w EPICS 3.14.11 & VxWorks 6.7 Jeff Hill
CA problem w EPICS 3.14.11 & VxWorks 6.7 GOURNAY Jean-Francois
Prev: RE: Modbus help emma.shepherd
Next: Re: CA problem w EPICS 3.14.11 & VxWorks 6.7 Kazuro FURUKAWA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA problem w EPICS 3.14.11 & VxWorks 6.7 Kazuro FURUKAWA
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
