1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm installation problems
To: John William Sinclair <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Thu, 3 Dec 2009 17:45:06 +0100
Now, it answers this:
../edmPrint.cc:1811: warning: deprecated conversion from string constant to ‘char*’ /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS - D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux - D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m32 -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/ os/Linux -I../../../../include/edm -I/home/jules/epics/base-3.14.10/ include/os/Linux -I/home/jules/epics/base-3.14.10/include -I/home/ jules/epics/extensions/include -I../../util -I../../lib -I/usr/ include -I/usr/include/X11 ../tag_pkg.cc ../tag_pkg.cc: In member function ‘int tagClass::decode(char*, char*, int)’: ../tag_pkg.cc:2596: warning: deprecated conversion from string constant to ‘char*’ /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS - D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux - D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m32 -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/ os/Linux -I../../../../include/edm -I/home/jules/epics/base-3.14.10/ include/os/Linux -I/home/jules/epics/base-3.14.10/include -I/home/ jules/epics/extensions/include -I../../util -I../../lib -I/usr/ include -I/usr/include/X11 ../remFileOpen.cc
../remFileOpen.cc: In function ‘int fileClose(FILE*)’:
../remFileOpen.cc:358: warning: deprecated conversion from string constant to ‘char*’
../remFileOpen.cc: In function ‘int fileReadable(char*)’:
../remFileOpen.cc:427: error: invalid conversion from ‘const char*’ to ‘char*’ ../remFileOpen.cc:429: error: invalid conversion from ‘const char*’ to ‘char*’ ../remFileOpen.cc:449: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc: In function ‘void discardParams(char*, int)’:
../remFileOpen.cc:482: error: invalid conversion from ‘const char*’ to ‘char*’ ../remFileOpen.cc:484: error: invalid conversion from ‘const char*’ to ‘char*’ ../remFileOpen.cc:506: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc: In function ‘void getParams(char*, char*, int)’:
../remFileOpen.cc:528: error: invalid conversion from ‘const char*’ to ‘char*’ ../remFileOpen.cc:530: error: invalid conversion from ‘const char*’ to ‘char*’ ../remFileOpen.cc:548: error: invalid conversion from ‘const char*’ to ‘char*’ ../remFileOpen.cc: In function ‘void reassemble(char*, char*, char*, int)’: ../remFileOpen.cc:570: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc: At global scope:
../remFileOpen.cc:365: warning: ‘int checkForHttp(char*, char*)’ defined but not used
make[2]: *** [remFileOpen.o] Error 1
make[2]: se sale del directorio `/home/jules/epics/extensions/src/edm/ lib/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: se sale del directorio `/home/jules/epics/extensions/src/edm/ lib'
make: *** [lib.install] Error 2
El 03/12/2009, a las 17:39, John William Sinclair escribió:
Julio,
You may be temporarily fix this by changing line 121 in utility.cc from
fd = open( g_diagFileName, O_CREAT|O_WRONLY );
to
fd = open( g_diagFileName, O_CREAT|O_WRONLY, 0777 );
I'll fix it in the next release.
John Sinclair
Julio Calvo wrote:
Hello, it is my first time here, I am Julio from Madrid. I would like to ask you help with the EDM installation. I have follow the README instructions, I have installed previously, SDDS, zlib, libpng, giflib....
But:
../utility.cc:7101: warning: deprecated conversion from string constant to ‘char*’
In file included from /usr/include/fcntl.h:217,
               from ../utility.h:26,
               from ../utility.cc:21:
In function ‘int open(const char*, int, ...)’,
  inlined from ‘int logDiagnostic(char*)’ at ../utility.cc:121:
/usr/include/bits/fcntl2.h:51: error: call to ‘__open_missing_mode’ declared with attribute error: open with O_CREAT in second argument needs 3 arguments
make[2]: *** [utility.o] Error 1
make[2]: se sale del directorio `/home/jules/epics/extensions/src/ edm/lib/O.linux-x86'
make[1]: se sale del directorio `/home/jules/epics/extensions/src/ edm/lib'
Any help?
Thank you si much.
Julio.
edm installation problems Julio Calvo
Re: edm installation problems John William Sinclair
Prev: Re: edm installation problems John William Sinclair
Next: Re: arpresolve: can't allocate llinfo0xc26180 (CA_UDP): Steven M. Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: support for keithley 2612 source meter David Kline
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
