1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: arpresolve: can't allocate llinfo0xc26180 (CA_UDP):
To: leige <[email protected]>
Date: Thu, 03 Dec 2009 11:59:19 -0500
leige wrote:
Recently we experienced a trouble in one IOC, it does not respond to telnet, but it says alive if I ping it. New CA connections can not be setup to it, but those CAs which have been setup can work normally. We got lots of warnings on this IOC's console,
-> 0xc26180 (CA_UDP): arpresolve: can't allocate llinfo0xc26180 (CA_UDP): arpres
olve: can't allocate llinfo0xc26180 (CA_UDP): arpresolve: can't allocate llinfo0
"arpresolve: can't allocate llinfo" usually indicates an incorrect netmask (or may be a bad route). Your IOC is sending out an arp request to map an IP address to a MAC address on the local network and is getting back a response which appears to not be local. Check the netmask on the IOC (ifShow). If that looks OK, check the routing table (routeShow) and the arp table (arptabShow). If that doesn't show you the problem, try snooping the network to see which IP address it is looking up and which host on the network is responding.
Steven Hartman
[email protected] || 865-466-6473
procServ softIOC server - V2.5.0 released Ralph Lange
arpresolve: can't allocate llinfo0xc26180 (CA_UDP): leige
Prev: Re: edm installation problems Julio Calvo Pinto
Next: support for keithley 2612 source meter David Kline
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: arpresolve: can't allocate llinfo0xc26180 (CA_UDP): leige
Next: Re: procServ softIOC server - V2.5.0 released Ralph Lange
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
