Why does a patch to asynOctet have this effect? The code's using VXI-11, which does provide the get/set EOS methods. If the higher level code isn't using these is it not an indication of a deeper problem?
On Dec 6, 2009, at 1:55 PM, Szalata, Zenon M. wrote:
> Hi Mark and Thank you,
> I applied the patch as instructed and now my IOC works with asyn R4.12.
> So, for me the problem is fixed. I will do more testing.
> Zen
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Sunday, December 06, 2009 9:54 AM
> To: Szalata, Zenon M.; Eric Norum
> Cc: TECHTALK Tech-Talk
> Subject: RE: asyn R4.10, R4.11, R4.12
> Hi Zen,
> I think the best solution to this is for the default implementation of
> asynOctet->getInputEos and getOutputEos to return asynSuccess and
> *eoslen=0.
> I've attached a patch for asynOctetBase.c against the R4-12 release.
> Can you give it a try and see if it fixes the problem?
> Thanks,
> Mark
> ________________________________
> From: Szalata, Zenon M. [mailto:[email protected]]
> Sent: Sun 12/6/2009 10:51 AM
> To: Mark Rivers; Eric Norum
> Hi Mark,
> Here is the result of dbpr "CAM:ASYN:IO",5:
> epics> dbpr "CAM:ASYN:IO",5
> ACKS: NO_ALARM ACKT: YES ACMD: None ADDR: 12
> AINP: AOUT: AQR: 0 ASG:
> ASP: 0x00000000 AUCT: autoConnect BAUD: Unknown BINP: 0
> BKPT: 0x00 BOUT: 0 CNCT: Connect DBIT:
> Unknown
> DESC: asyn IO DISA: 0 DISP: 0 DISS:
> NO_ALARM
> DISV: 1 DPVT: 0xf0f85c09 DRVINFO: DSET:
> 0x488a5b00
> DTYP: asynRecordDevice ENBL: Enable EOMR: None
> ERRS: 0xd8fb5c09 EVNT: 0 F64INP: 0 F64IV: 0
> F64OUT: 0 FCTL: Unknown FLNK:DB_LINK CAM:FO:IO:DATA
> GPIBIV: 1 I32INP: 0 I32IV: 1 I32OUT: 0
> IEOS: IFACE: asynOctet IFMT: Binary IMAX: 80
> IPTR: 0x28fb5c09 LCNT: 0 LSET: 0xd0d35d09 MCTL:
> Unknown
> MLIS: 0x000000000000000000000000 MLOK: 0xd8f85c09 NAME:
> CAM:ASYN:IO
> NAWT: 0 NORD: 0 NOWT: 6 NRRD: 0
> NSEV: NO_ALARM NSTA: NO_ALARM OCTETIV: 1 OEOS:
> OFMT: Binary OMAX: 80 OPTIONIV: 1 OPTR:
> 0xd0fa5c09
> PACT: 0 PCNCT: Connect PHAS: 0 PINI: NO
> PORT: L0 PPN: 0x00000000 PPNR: 0x00000000 PRIO: LOW
> PROC: 0 PRTY: Unknown PUTF: 0 RDES:
> 0x58855909
> REASON: 0 RPRO: 0 RSET: 0x008a5b00 SBIT:
> Unknown
> SCAN: Passive SDIS:CONSTANT SEVR: NO_ALARM SOCK:
> SPR: 0 SPVT: 0x00000000 STAT: NO_ALARM TB0: On
> TB1: Off TB2: Off TB3: Off TB4: Off
> TFIL: Unknown TIB0: Off TIB1: Off TIB2: Off
> TIME: 2009-12-06 08:51:04.871003000 TINP: TIOM: 0
> TMOD: Write/Read TMOT: 1 TMSK: 1 TPRO: 0
> TSE: 0 TSEL:CONSTANT TSIZ: 80 UCMD: None
> UDF: 0 UI32INP: 0 UI32IV: 0 UI32MASK:
> 4294967295
> UI32OUT: 0 VAL:
> epics>
> Thanks,
> Zen
> Sent: Saturday, December 05, 2009 9:43 PM
> Are you using the asyn record? If so, then do a
> dbpr "myAsynRecord" 5
> to see what you have set the EOS string to.
> Mark
> From: [email protected] on behalf of Szalata, Zenon M.
> Sent: Sat 12/5/2009 11:38 PM
> To: Eric Norum
> I am not aware of explicitly specifying the EOS string. I thought that
> EOS string was not used and only the EOI was. That is, the KS3988 GPIB
> CAMAC crate controller does not require nor accepts an EOS string. I
> maybe wrong on this. Perhaps, somehow unwittingly I am sending some EOS
> string? How can I verify that?
> Actually, in my original message I told a lie, I am not using
> streamdevice, just asyn.
> Why does it work with asyn R4.9 and not with the newer versions? Is it
> possible that starting with R4.10 default behavior changed? Could it
> be, that starting with R4.10 I have to explicitly say no EOS?
> Zen
> From: Eric Norum [mailto:[email protected]]
> Sent: Saturday, December 05, 2009 9:01 PM
> Subject: Re: asyn R4.10, R4.11, R4.12
> The E5810A allows only a single EOS character. Are you trying to use a
> longer end-of-string?
> On Dec 5, 2009, at 8:51 PM, Szalata, Zenon M. wrote:
>> Hi Eric,
>> I am using Agilent E5810A.
>> Here is a line from the st.cmd file:
>> vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
>> Thank you,
>> Zen
>> Sent: Saturday, December 05, 2009 8:35 PM
>> What GPIB controller are you using?
>> On Dec 5, 2009, at 5:42 PM, Szalata, Zenon M. wrote:
>>> I have a simple soft IOC which uses asyn and streamdevice. It does
> IO
>>> with KS3988 GPIB CAMAC crate controller. The IOC works correctly
> with
>>> asyn R4.9. I have installed asyn R4.12 and my IOC does not work with
>>> asyn R4.12. I get the following message: "EOS TOO LONG". I also
>> tried
>>> asyn R4.11 and R4.10 I see the same message with these the two
>> versions
>>> of asyn as I see with the latest.
>>> How do I overcome this difficulty? Do these newer versions of asyn
>>> require that I make some change to my IOC? Can someone help me with
>>> this, please?
>>> For now I am forced to stay with asyn R4.9.
>>> Thanks,
>>> Zen
>> Eric Norum
>> [email protected]
> Eric Norum
> [email protected]
Eric Norum
[email protected]
- RE: asyn R4.10, R4.11, R4.12 Mark Rivers
- asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
- Re: asyn R4.10, R4.11, R4.12 Eric Norum
- RE: asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
<2009>
2025
2026
<2009>
2025
2026
