1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn On Cygwin
From: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
To: "'Mark Rivers'" <[email protected]>, <[email protected]>
Date: Tue, 8 Dec 2009 14:46:42 -0700
Thank you Mark, asyn compiled fine after the CONFIG_SITE change.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone:                   505-881-8887
Fax:                       505-888-0651
Address:                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
Sent: Tuesday, December 08, 2009 2:18 PM
To: Pawel Kowalski - BiRa Systems Inc.; [email protected]
The problem is that the Cygiwn build only works with STATIC_BUILD=YES, SHARED_LIBRARIES=NO.  Change your CONFIG_SITE.cygwin32-cygwin32 to select these options and rebuilt base and asyn.
From: [email protected] [mailto:[email protected]] On Behalf Of Pawel Kowalski - BiRa Systems Inc.
Sent: Tuesday, December 08, 2009 3:14 PM
To: [email protected]
Subject: Asyn On Cygwin
Hello,
I am trying to move an application we set up on an openSuse linux distribution to a windows machine running cygwin. I am trying to compile Asyn on cygwin and I am running in to trouble. I attached the console output. Before I got this error I had another issue with the command rpcgen so I went ahead and installed the Sun RPC package which was hopefully the right package to install (it did fix the error with rpcgen not being found). Thank you in advance, help would be appreciated.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone:                   505-881-8887
Fax:                       505-888-0651
STE A
Asyn On Cygwin Pawel Kowalski - BiRa Systems Inc.
RE: Asyn On Cygwin Mark Rivers
Prev: RE: Asyn On Cygwin Mark Rivers
Next: Re: Fwd: CA link behavior Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EDM on Cygwin Pawel Kowalski - BiRa Systems Inc.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
