1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM on Cygwin
From: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
To: <[email protected]>
Date: Wed, 9 Dec 2009 08:44:29 -0700
Hello,
I am having an issue with getting EDM to compile on cygwin. I noticed that in the EDM documentation it says that LessTif is not recommended; but that seems to be the only option available with cygwin as I can’t find the OpenMotif package. Is this my issue or am I doing something else wrong? I also saw that the makefiles under EDM set SHARED_LIBRARIES = YES, is this a problem under cygwin?
I attached the make log, help would be appreciated.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone:                   505-881-8887
Fax:                       505-888-0651
Address:                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
Pawel Kowalski@bira-a4f57d2df6 /epics/base/extensions/src/edm
$ make
make -C ./util install
make[1]: Entering directory `/epics/base/extensions/src/edm/util'
make -C O.cygwin-x86 -f ../Makefile TOP=../../../.. T_A=cygwin-x86 install
make[2]: Entering directory `/epics/base/extensions/src/edm/util/O.cygwin-x86'
make[2]: *** No rule to make target `../O.Common/os.h', needed by `inc'.  Stop.
make[2]: Leaving directory `/epics/base/extensions/src/edm/util/O.cygwin-x86'
make[1]: *** [install.cygwin-x86] Error 2
make[1]: Leaving directory `/epics/base/extensions/src/edm/util'
make: *** [util.install] Error 2
Re: EDM on Cygwin John William Sinclair
Prev: RE: Support for PI C863 Gabadinho Jose
Next: Re: EDM on Cygwin John William Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Asyn On Cygwin Pawel Kowalski - BiRa Systems Inc.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
