Pawel,
EDM will never, ever build on cygwin.
Note that a new initiative is in the works to build control system gui
tools using the eclipse
RCP platform. This will give you access from windows.
There is also an older display manager, MEDM, which I believe will
compile in a windows
environment with certain 3rd party X Windows tools. I don't know the
details but someone
on the tech-talk list may be able to help.
John Sinclair
Pawel Kowalski - BiRa Systems Inc. wrote:
Hello,
I am having an issue with getting EDM to compile on cygwin. I noticed
that in the EDM documentation it says that LessTif is not recommended;
but that seems to be the only option available with cygwin as I can’t
find the OpenMotif package. Is this my issue or am I doing something
else wrong? I also saw that the makefiles under EDM set
SHARED_LIBRARIES = YES, is this a problem under cygwin?
I attached the make log, help would be appreciated.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com <http://www.bira.com>
*Phone:* 505-881-8887
*Fax:* 505-888-0651
*Address:* 2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
Pawel Kowalski@bira-a4f57d2df6 /epics/base/extensions/src/edm
$ make
make -C ./util install
make[1]: Entering directory `/epics/base/extensions/src/edm/util'
make -C O.cygwin-x86 -f ../Makefile TOP=../../../.. T_A=cygwin-x86 install
make[2]: Entering directory `/epics/base/extensions/src/edm/util/O.cygwin-x86'
make[2]: *** No rule to make target `../O.Common/os.h', needed by `inc'. Stop.
make[2]: Leaving directory `/epics/base/extensions/src/edm/util/O.cygwin-x86'
make[1]: *** [install.cygwin-x86] Error 2
make[1]: Leaving directory `/epics/base/extensions/src/edm/util'
make: *** [util.install] Error 2
- RE: EDM on Cygwin Mark Rivers
- EDM on Cygwin Pawel Kowalski - BiRa Systems Inc.
<2009>
2025
2026
<2009>
2025
2026
