On Wednesday 09 December 2009 15:06:23 Ralph Lange wrote:
> I can see the unexpected string type link behavior possibly being
> intended to do something like an auto-save/restore on record C. This
> could be an interesting feature, if (and only if) it is independent from
> data type (obviously) and configurable (which requires a CA protocol
> change to allow the link spec to define target record processing -
> instead of the PP option of the target field now used for that purpose).
I subsequently discovered that the only reason that non-string output links do
not replicate the string behavior and re-send their last value when the target
IOC reboots is probably because of a typo made in 1996. Both branches of a
conditional contain the line
plink->value.pv_link.pvlMask |= pvlOptOutString;
but arguably one of them should actually say
plink->value.pv_link.pvlMask |= pvlOptOutNative;
which would make all output links re-do their puts on reconnect. There is no
other purpose for those two bits in the pvlMask.
Also, this behavior only happens when CA reports the native channel type as an
ENUM and the value being put is a string, so it doesn't currently happen for
all string outputs.
I do not plan to make the above change, and in fact I will probably comment
out both lines, because in the future I think we should look at adding a flag
(ROR = Resend On Reconnect?) to output links to allow users to turn this
behavior on. I can see it as being useful in some cases. I'm not so sure
about the idea of a put without causing processing though...
Having a related flag to control the reconnect behavior of CP input links
might be worth considering.
- Andrew (leaving for home through the snow-storm now)
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: Fwd: CA link behavior Ralph Lange
- Re: CA link behavior Andrew Johnson
- Re: Fwd: CA link behavior Dirk Zimoch
Re: Odd widget layout in EDM on OS X Pelaia II, Tom
RE: Any News on EPICS 3.14.11 with vxWorks 6.7 Jeff Hill
<2009>
2025
2026
<2009>
2025
2026
