1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Odd widget layout in EDM on OS X
To: [email protected], Eric Norum <[email protected]>
Date: Thu, 10 Dec 2009 11:09:10 +0900
Hi Eric,
(09/12/10 6:33), Eric Norum wrote:
> I downloaded and built EDM (edm-1-12-24.tgz) on my OS X (10.6.12) machine.   I'm using Open Motif 2.3.2-2.  There appears to be something wrong with the spacing, though.  For example, here's what the Button Properties window looks like when I try to create a new button.  As you can see, it's going to be a little tricky to set the properties!
> Any ideas as to where to look for a solution?
 I had same problem. Back to the openMotif-2.2.3 solved the problem for me.
Noboru Yamamoto
J-PARC control group
J-PARC center, KEK & JAEA
JAPAN
Re: Odd widget layout in EDM on OS X Eric Norum
Prev: RE: Any News on EPICS 3.14.11 with vxWorks 6.7 Jeff Hill
Next: Re: Odd widget layout in EDM on OS X Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Odd widget layout in EDM on OS X Pelaia II, Tom
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
