1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Odd widget layout in EDM on OS X
To: Noboru Yamamoto <[email protected]>
Cc: TECHTALK Tech-Talk <[email protected]>
Date: Wed, 9 Dec 2009 20:00:05 -0800
Thanks very much.  I had an older version of OpenMotif around (2.2.4).  I compiled against that and now things are working fine.  It appears that OpenMotif 2.3.2 was the culprit.
EDM maintainers -- perhaps this should be added to a 'known problems' file in the distribution.
Thanks!
On Dec 9, 2009, at 6:09 PM, Noboru Yamamoto wrote:
> Hi Eric,
> (09/12/10 6:33), Eric Norum wrote:
>> I downloaded and built EDM (edm-1-12-24.tgz) on my OS X (10.6.12) machine.   I'm using Open Motif 2.3.2-2.  There appears to be something wrong with the spacing, though.  For example, here's what the Button Properties window looks like when I try to create a new button.  As you can see, it's going to be a little tricky to set the properties!
>> Any ideas as to where to look for a solution?
> I had same problem. Back to the openMotif-2.2.3 solved the problem for me.
> Regards,
> Noboru Yamamoto
> J-PARC control group
> J-PARC center, KEK & JAEA
> JAPAN
Eric Norum
[email protected]
Odd widget layout in EDM on OS X Eric Norum
Re: Odd widget layout in EDM on OS X Noboru Yamamoto
Prev: Re: Odd widget layout in EDM on OS X Noboru Yamamoto
Next: Re: Odd widget layout in EDM on OS X Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
