1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS database comparison
To: [email protected]
Date: Thu, 10 Dec 2009 15:06:59 -0700
Title: Re: EPICS database comparison
The script below sorts record definition blocks, but not the fields within a record.  The "record" header must begin in column 1 and the record's closing bracket must be the last non-whitespace character on the line.
#!/usr/local/bin/perl
# File: recordSort
# Purpose: Sort an EPICS .db file by record name.
# Usage: recordSort <file>
$name = '!';
$block = '';
while( <>) {
  if ( /^record.*"(.*)"/) {
    $name = $1;
    $block = $_;
  else {
    $block .= $_;
    if ( /\}\s*$/) {
      $block{ $name} = $block;
      undef $block;
foreach $name ( sort keys %block) { print $block{ $name};}
# EOF
EPICS database comparison Pam Gurd
Prev: Re: EPICS database comparison Andrew Johnson
Next: Reading an array of strings from a Waveform record Simon Hoyle
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
