Title: RE: Remote I/O
Hi Bob,
Dalesio, Leo wrote:
This ability to define the PLC code and logic in
ASCII was the primary reason identified by David Dudley in our choice
for AB over Siemens and Yokogawa. Yokogawa has responded that they plan
to add this ability.
Matthias - are you saying that you can do this with
the Siemens PLC? Can you define the logic in ASCII as well?
I am sorry - it is not the logic itself but the memory layout of all
the nodes on the Profibus (including the memory layout of the PLC)
which we configure with a CSS tool. This generates a XML files which
gets loaded to the IOC.
This was possible because we have the driver source code in our hands.
Using the Siemens tools you will generate a binary file which will be
loaded to the hardware board by some Windows DLLs - so no way to get
this running on Linux or vxWorks :-(
Why would you want to cerate an ASCII file of the actual logic? Isn't
this loaded via Ethernet to the PLC or burned into EPROM? Or are you
loading the code to the PLCs via an IOC?
The cost of keeping the PLC software in synch with
the IOC was considered significant.
There's a payload on both sides - the PLC and the IOC.
You need to map PLC-IO into the memory of the (PLC) communication
controller and map another time the memory in the dual ported RAM on
the IOC into EPICS record addresses. Both configurations (except the
PLC program itself) can be handled with our solution.
Cheers
Matthias
-----Original Message-----
Matthias Clausen
Sent: Wed 12/16/2009 10:02 AM
To: Ralph Lange
Cc: EPICS Tech Talk
Subject: Re: Remote I/O
Hi Ralph,
Ralph Lange wrote:
> On Wed 16 Dec 2009 8:16:17 Matthias Clausen wrote:
>> Hi Nick,
>> [...] In our case sensors and actors are
directly connected to
>> Profibus. The remaining I/O is connected
through WaGo I/O with a
>> Profibus controller. Profibus driver and
configuration is available
>> from us - even with redundancy support...
> Hi Matthias,
> is that using the 1996 IPAC-Profibus Interface
that is listed in the
> hardware support database on the EPICS web site?
no - it's a new driver which support the Softing PC
104 cards. Softing
is now producing also a Compact PCI card for us.
There's a special firmware available which supports
redundant Profibus
connections and fail-over - in conjunction with the
redundant IOC.
Configuring Profibus (DP - or PA) is quite
complicated. You have to map
memory space of the I/O devices into the DPM on the
IOC. So you need to
configure your records's addresses in a way that they
match with the DMP
layout.
We have developed a configuration tool in CSS which
creates an XML file.
(Like the Siemens 'Step 7' tool) This file is parsed
on the IOC and
creates the memory layout in the DPM. The EPICS
records get their
Profibus address from a reference in the configuration
database. (When
the db files gets created)
We should finally write some documentation about it
Thanks
-Matthias
> Ralph
Matthias Clausen Cryogenic
Controls Group(MKS-2)
phone: +49-40-8998-3256 Deutsches
Elektronen Synchrotron
fax:
+49-40-8994-3256 Notkestr. 85
e-mail:
[email protected] 22607 Hamburg
WWW-MKS2.desy.de
Germany
Matthias Clausen Cryogenic Controls Group(MKS-2)
phone: +49-40-8998-3256 Deutsches Elektronen Synchrotron
fax: +49-40-8994-3256 Notkestr. 85
e-mail: [email protected] 22607 Hamburg
WWW-MKS2.desy.de Germany
- Re: Remote I/O Wesley Moore
- Re: Remote I/O David Dudley
- RE: Remote I/O Dalesio, Leo
- Remote I/O nick.rees
- Re: Remote I/O Matthias Clausen
- Re: Remote I/O Ralph Lange
Updated 8, 12 ,13 and 14-bit EPICS scopes Boyd Shaw
Re: Remote I/O Bruce Hill
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
