Note that ControlLogix communications (multicast with tcp messaging)
includes a fairly severe penalty for using the
tag names. There are a limited number of cip resources (255 is common).
Each module consumes several and each IOC access
by tag name consumes one. As a result, we always use arrays and end up
in the same old boat of having to do lots of name
mapping to array position. In principle the tag names are very nice; in
practice they are not too useful.
John Sinclair
David Dudley wrote:
For NSLS-2, all configuration and logic is planned to be incorporated
into the IRMIS system, as a single database layout.
In addition, I should have initially mentioned that one of the primary
reasons for the A-B choice is that it uses a communications format
named ‘CIP’, and its internal memory configuration is entirely driven
by TAGNames.
In tne ControlLogix platform, you do not do programming or
configuration by having to remember or know things like “...
‘B-703:R-E5<OTB>T-1’ is wired to terminal IW102... (That’s Building
703, Room E5, Optical Testing Lab, Temperature 1)” .
- Re: Remote I/O David Dudley
RE: New home for asyn Mark Rivers
mbboDirect problem Dirk Zimoch
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
