1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbboDirect problem
To: tech-talk <[email protected]>
Date: Fri, 18 Dec 2009 15:38:35 +0100
Hi all,
I have a quite nasty problem with the mbboDirect record.
When I write a bit pattern directly into the VAL field instead of B0...BF, and the record has UDF=1, the record writes out the old value instead of the new one. According to the record reference manual, this is not an illegal operation.
Normally it works. Even if the UDF becomes true during run-time, the worst thing that happens is that the new value is ignored (which is already bad enough). But after a reboot the record writes out 0 (and thus switches off all connected hardware).
The problem is here:
static long process(mbboDirectRecord *prec)
    if (!prec->pact) {
	if(prec->udf) {
	    recGblSetSevr(prec,UDF_ALARM,INVALID_ALARM);
	    goto CONTINUE;
	/* convert val to rval */
	convert(prec);
CONTINUE:
I am not sure what the purpose of this code is. The record never sets udf true. Thus only the device support can do so. Thus it cannot make sense the test udf BEFORE the device support is called.
Best regards,
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: mbboDirect problem Andrew Johnson
Prev: Re: Remote I/O John William Sinclair
Next: Re: Remote I/O & RT linux David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: labCa 3.1 for Windows John Dobbins
Next: Re: mbboDirect problem Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
