1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: drvAsynIPServerPortConfigure
To: EPICS tech-talk <[email protected]>
Date: Wed, 20 Jan 2010 08:59:02 +0000
Hello,
The asyn documentation says that drvAsynIPServerPortConfigure can be a
TCP or UDP server but the source code in
asyn/drvAsynSerial/drvAsynIPServerPort.c does a
listen(tty->fd, tty->maxClients);
There is no recvfrom call so surely this is TCP only?
Also this code below fails to convert the protocol string in the string
"localhost:9600 udp" because the format string uses %ud which looks for
an unsigned integer followed by a 'd'. It should be just "%u". This
stops it from ever seeing the "udp" protocol specifier. This exists in
all of the version of asyn I have looked at (4-9 to 4-12).
 * Parse configuration parameters
  protocol[0] = '\0';
  if (((cp = strchr(serverInfo, ':')) == NULL)
     || (sscanf(cp, ":%ud %5s", &tty->portNumber, protocol) < 1))
    printf("drvAsynIPPortConfigure: \"%s\" is not of the form
\"<host>:<port>[protocol]\"\n",tty->serverInfo);
    ttyCleanup(tty);
    return -1;
Would it be possible to use stream device to handle incoming UDP data?
Paul.
RE: drvAsynIPServerPortConfigure Mark Rivers
Prev: Re: epics on launchpad! Benjamin Franksen
Next: RE: drvAsynIPServerPortConfigure Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Auto Save/Restore issue... Tim Mooney
