1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: drvAsynIPServerPortConfigure
To: "Paul Hamadyk" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Wed, 20 Jan 2010 07:57:20 -0600
Hi Paul,
You are correct, drvAsynIPServerPortConfigure can only handle TCP, and the documentation is wrong.
Eric Norum looked at adding UDP support to this code back in December.  He concluded it was a fairly big job, but he did fix the sscanf problem for the next release.  If you or someone else wants to add UDP support that would be great!
Sent: Wed 1/20/2010 2:59 AM
To: EPICS tech-talk
Subject: drvAsynIPServerPortConfigure
Hello,
The asyn documentation says that drvAsynIPServerPortConfigure can be a
TCP or UDP server but the source code in
asyn/drvAsynSerial/drvAsynIPServerPort.c does a
listen(tty->fd, tty->maxClients);
There is no recvfrom call so surely this is TCP only?
Also this code below fails to convert the protocol string in the string
"localhost:9600 udp" because the format string uses %ud which looks for
an unsigned integer followed by a 'd'. It should be just "%u". This
stops it from ever seeing the "udp" protocol specifier. This exists in
all of the version of asyn I have looked at (4-9 to 4-12).
 * Parse configuration parameters
  protocol[0] = '\0';
  if (((cp = strchr(serverInfo, ':')) == NULL)
     || (sscanf(cp, ":%ud %5s", &tty->portNumber, protocol) < 1))
    printf("drvAsynIPPortConfigure: \"%s\" is not of the form
\"<host>:<port>[protocol]\"\n",tty->serverInfo);
    ttyCleanup(tty);
    return -1;
Would it be possible to use stream device to handle incoming UDP data?
Paul.
drvAsynIPServerPortConfigure Paul Hamadyk
Prev: drvAsynIPServerPortConfigure Paul Hamadyk
Next: Ipac with VIPC616 wmoore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
