CPU: ------- We have tested several CPUs and many of them failed running the redundancy communication on the second Ethernet. We have now selected one CPU which is running very stable: For high CPU load - but with active cooling: Application: Redundant cryo IOC >= 2000 records Kontron type CP307 We will test next week: For medium CPU load without active (fan) cooling: Application: Small redundant IOSs; communication with PLCs on the second Ethernet; any other EPICS IOC Kontron type CP305 (Atom processor) Both CPUs with latest vxWorks BSP. Both CPUs come with several different options - like rear I/O etc. The advantage of the CP305 is that not only the power consumption is low - also the price is attractive. For now we are only running a (up to four) Profibus boards from Softing in the crates - with full redundancy support on the Profibus (special firmware from Softing). - No direct I/O Crates: --------- We have a set of new creates designed by DESY - implemented by ELMA in Germany DIN-Rail: (IOC in the field - can be mounted on DIN-rail) Dual power supply four slot cPCI 19" (redundant IOC) 2X dual power and four cPCI 19" (multi slot) 1X dual power eight slot cPCI If you need more details - contact us
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
