For a small and short-lived test setup my A-B ControlLogix PLC needs
to read some EPICS values from another system. What are my options?
How about using an Ethernet/IP server library? I.e. write a program
that uses EZCA to poll the EPICS values periodically, then serve them
to the PLC via Ethernet/IP...does this work?
For your "small and short-lived test setup", set up your own IOC
with ao records, DOL the "real" PV from the real IOC, OMSL
closed-loop, OUT to a tag on your PLC, with DTYP etherIP
(http://ics-web.sns.ornl.gov/kasemir/etherip/index.html).
Steven Hartman
[email protected] || 865-466-6473
- Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
- RE: Accessing EPICS PV from Allen-Bradley PLC Mark Rivers
- Re: Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
Re: Accessing EPICS PV from Allen-Bradley PLC Mohan Ramanathan
RE: epics build with cmake Davidsaver, Michael
<2010>
2025
2026
Intel C Compiler icc on linux? Carl Lionberger
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
